Super Glue or,,,?? |
Post Reply |
desertjoe
Orange Level Access Joined: 23 Sep 2013 Location: New mexico Points: 13525 |
Posted: 17 Sep 2024 at 2:48pm |
The neck of the black plastic gas tank on my Polaris ATV has cracked along one of the threads and cap is a little loose. What are other's best attempts using some type of super glue or ,,,,????
Hubert (Ga)engine7
Orange Level Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6228 |
I use two part epoxy to repair cracks in some of my gasoline containers.
plummerscarin
Orange Level Access Joined: 22 Jun 2015 Location: ia Points: 3364 |
I used a heat gun and plastic weld rod to repair Cub Cadet gas tank
jaybmiller
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 22223 |
Crazy Glue (aka Cyanoacrlate (sp) ) is NOT waterproof. Determine WHAT kind of 'plastic' the tank's made from. Maybe HDPE ? Should be on the tank in a triangle, or check MFR's website ? Get a glue specifically DESIGNED for that plastic !!
Thad in AR.
Orange Level Access Joined: 12 Sep 2009 Location: Arkansas Points: 9395 |
My first attempt would be JB Weld
im4racin
Orange Level Joined: 12 Jun 2017 Location: Garrison ND Points: 912 |
Windshield urethane
AllisFreak MN
Orange Level Access Joined: 07 Dec 2009 Location: Minnesota Points: 1538 |
Remove cap, park a Yamaha under it, re install cap.
desertjoe
UMMmmm,,now,,,,why did I not think bout using that,,,?? Something else would of been some of that glue (that I did buy some just last week) for the water distributor on my swamp cooler had a tube come loose and the glue Kit was special for that black plastic tubes,,,,?? Many THANKS Im4Racin,,,,
PaulB
Orange Level Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 4652 |
Not knowing exactly what the plastic is that you want to glue is like trying to weld cast iron with aluminum rod.
ekjdm14
Bronze Level Joined: 20 Aug 2024 Location: Manchester UK Points: 58 |
Already been more than covered but my first choice would be JB weld & second to that windshield glue. The latter sticks extremely well to pretty much any material you can think of, but especially to ones you DON'T want it stuck to. (Favourites here being forearms, hair & seat of pants, with resultant unintentional application to upholstery!)
BuckSkin
Silver Level Joined: 12 Sep 2019 Location: Poor Farm Points: 409 |
Been there and done that attempts on several plastic gasoline and diesel tanks and my experiences = fuel tanks are made of either PE or PP plastic, neither of which anything less than a hundred dollars a drop will permanently adhere to.
Epoxy Putty Stick, whatever brand of your choosing = they are all pretty much the same = will look and act like it is there until Kingdom Come --- for a couple weeks; and, then, the Epoxy will yield it's hold and either fall off or just sit there loose, depending on what kind of "mechanical" connection it has. No commonly available - read "affordable" - adhesive or sealant will adhere; it may look and act like it has stuck, but in short time will come loose. Depending on the break/crack, get yourself one of those $20 plastic welding hot staple guns like that hot Chickanic lady has a video all about = best $20 I ever spent. The one I got paid for itself six-times-over the very first thing I repaired with it. What it amounts to is a two-prong soldering gun with the looped soldering tip replaced with little steel staples of various shapes. There are a gazillion different kits on Amazon and most come with a lifetime supply of assorted staples. You select a staple, put the prongs in the gun tips, hold down the trigger for a second until the staple gets HOT, keep the trigger pressed while you melt the HOT staple down into the plastic. When the staple is buried in the plastic, keep holding it there while you release the trigger and let the staple cool; if you get in a hurry and don't allow the staple to cool in place, it will just pull out when you move the gun. Do this many many times along all breaks and cracks, being careful not to push the HOT staples all the way through; you want them at varying depths, but not through. Once you get everything sewn together with the staples, then follow up by welding the seams, either with a soldering iron, a wood-burning tool, or one of the many specific plastic welding tools. I have read that zip-tie cut-offs make good "welding rods" for fuel tank plastic. A wood-burning tool is probably best for welding plastic; as, they come with a whole assortment of various tips; one from Harbor Freight is plenty sufficient for the task.
HudCo
Orange Level Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3482 |
if you cant plastic weld it just get a used one from power sports nation
jaybmiller
re: cracked along one of the threads and cap is a little loose. gee, now I'm thinking if you use any glue, you'll never get that cap back off ! OK, option 63.... cut and glue a 'sleeve of plastic' inside the neck. Almost any glue will work as not much if any gas up there Sleeve acts to mechanically strengthen the neck Sleeve is a shield,prevents gas from dripping out Possible 'sleeve' could be PVC water pipe, ABS pipe, 2" central vacuum piping,some kids toy ? |
desertjoe
Post Reply | |
