Super Glue or,,,??
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Topic: Super Glue or,,,??
    Posted: 17 Sep 2024 at 2:48pm
 The neck of the black plastic gas tank on my Polaris ATV has cracked along one of the threads and cap is a little loose. What are other's best attempts using some type of super glue or ,,,,????
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2024 at 4:45pm
I use two part epoxy to repair cracks in some of my gasoline containers.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2024 at 4:54pm
I used a heat gun and plastic weld rod to repair Cub Cadet gas tank
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2024 at 5:16pm
Crazy Glue (aka Cyanoacrlate (sp) ) is NOT waterproof.
Determine WHAT kind of 'plastic' the tank's made from. Maybe HDPE ?
Should be on the tank in a triangle, or check MFR's website ?
Get a glue specifically DESIGNED for that plastic !!
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2024 at 5:45pm
My first attempt would be JB Weld
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2024 at 6:22pm
Windshield urethane
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2024 at 8:03pm
Remove cap, park a Yamaha under it, re install cap.  Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2024 at 10:23pm
Originally posted by im4racin im4racin wrote:
Windshield urethane
   UMMmmm,,now,,,,why did I not think bout using that,,,?? Something else would of been some of that glue (that I did buy some just last week) for the water distributor on my swamp cooler had a tube come loose and the glue Kit was special for that black plastic tubes,,,,??
  Many THANKS Im4Racin,,,,ClapClap
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 7:06am
Not knowing exactly what the plastic is that you want to glue is like trying to weld cast iron with aluminum rod.
ekjdm14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 10:41am
Already been more than covered but my first choice would be JB weld & second to that windshield glue. The latter sticks extremely well to pretty much any material you can think of, but especially to ones you DON'T want it stuck to. (Favourites here being forearms, hair & seat of pants, with resultant unintentional application to upholstery!)
BuckSkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Posted: 21 hours 38 minutes ago at 4:12pm
Been there and done that attempts on several plastic gasoline and diesel tanks and my experiences = fuel tanks are made of either PE or PP plastic, neither of which anything less than a hundred dollars a drop will permanently adhere to.
Epoxy Putty Stick, whatever brand of your choosing = they are all pretty much the same = will look and act like it is there until Kingdom Come --- for a couple weeks; and, then, the Epoxy will yield it's hold and either fall off or just sit there loose, depending on what kind of "mechanical" connection it has.
No commonly available - read "affordable"  - adhesive or sealant will adhere; it may look and act like it has stuck, but in short time will come loose.
Depending on the break/crack, get yourself one of those $20 plastic welding hot staple guns like that hot Chickanic lady has a video all about = best $20 I ever spent.
The one I got paid for itself six-times-over the very first thing I repaired with it.
What it amounts to is a two-prong soldering gun with the looped soldering tip replaced with little steel staples of various shapes.
There are a gazillion different kits on Amazon and most come with a lifetime supply of assorted staples.
You select a staple, put the prongs in the gun tips, hold down the trigger for a second until the staple gets HOT, keep the trigger pressed while you melt the HOT staple down into the plastic.
When the staple is buried in the plastic, keep holding it there while you release the trigger and let the staple cool; if you get in a hurry and don't allow the staple to cool in place, it will just pull out when you move the gun.
Do this many many times along all breaks and cracks, being careful not to push the HOT staples all the way through; you want them at varying depths, but not through.
Once you get everything sewn together with the staples, then follow up by welding the seams, either with a soldering iron, a wood-burning tool, or one of the many specific plastic welding tools.
I have read that zip-tie cut-offs make good "welding rods" for fuel tank plastic.
A wood-burning tool is probably best for welding plastic; as, they come with a whole assortment of various tips; one from Harbor Freight is plenty sufficient for the task.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 16 hours 58 minutes ago at 8:52pm
if you cant plastic weld it just get a used one from power sports nation
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 7 hours 56 minutes ago at 5:54am
re: cracked along one of the threads and cap is a little loose.
gee, now I'm thinking if you use any glue, you'll never get that cap back off !Wink
OK, option 63.... cut and glue a 'sleeve of plastic' inside the neck.
Almost any glue will work as not much if any gas up there
Sleeve acts to mechanically strengthen the neck
Sleeve is a shield,prevents gas from dripping out
Possible 'sleeve' could be PVC water pipe, ABS pipe, 2" central vacuum piping,some kids toy ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 56 minutes ago at 8:54am
   That right there is a GREAT idea,,,Jay,,,!!! I'm fixing to go to Lumber yard to check out the OD's of the PVC pipe fittings along with a threaded cap if possible,,,,!!! More than one way to skin a cat besides,,,,,UMmmmmm,,,never mind,,,,WinkClap
