Super Duty Speedometer ?? |
Page 12> |
| Author | ||
FREEDGUY
Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
Topic: Super Duty Speedometer ??Posted: 21 Jan 2022 at 5:20pm |
I was driving to work this morning and looked down at the dash and NO MPH reading was shown
![]() !! All other gauges were functioning INCLUDING the TACH
| Sponsored Links | ||
TomC
Joined: 24 Nov 2017 Location: Hillsboro, MO Points: 1549 |
Posted: 21 Jan 2022 at 5:27pm |
Hummmmm, the speedometer is broken?
Lars(wi)
Joined: 14 Sep 2009 Location: Permian Basin Points: 8402 |
Posted: 21 Jan 2022 at 5:31pm |
Did it stay that way? Or was it temporary? Did it return to function, after it warmed up later in the day? |
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34626 |
Posted: 21 Jan 2022 at 5:36pm |
dam ferds The old '92 F250 /460 starting to have issues where the speedo don't show nothing and the truck will shift only by slamming into gear. Jiggle and push in the reset, then the speedometer wakes up and works, as well as the transmission starts working correctly again. Stupid derfs.
FREEDGUY
Posted: 21 Jan 2022 at 5:46pm |
It started functioning again after 11 miles and has worked "so far" on the trip home (21 miles)
FREEDGUY
Posted: 21 Jan 2022 at 5:47pm |
Luckily, no tranny issues
![]() !! Thanks for the reply![]() |
FREEDGUY
Posted: 21 Jan 2022 at 5:56pm |
On a side-note, where's the back-up light switch located ? Please tell me it's not on the bowels of the steering column on an automatic
. Thanks
Joined: 11 Sep 2009 Location: illinois Points: 90826 |
Posted: 21 Jan 2022 at 6:11pm |
the speedos on FORDS built in the 2005 range were not mechanical cable... They have a VSS ( vehicle speed sensor) on the transmission tail shaft ... If the sensor "speed pickup" has crud on the face, or spot of ICE due to freezeing, etc.. then it will not read.. After the "crud" washes off, the speed comes back.
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55283 |
Posted: 21 Jan 2022 at 6:14pm |
Blue oval fluid sprayed on the speedo cables and wiring will fix it!
FREEDGUY
Posted: 21 Jan 2022 at 6:16pm |
Thanks Steve, it happened to be the coldest temps this morning that our region has seen "so far" this season. Would the lack of speedo reading effect the engine computer at the same time ? The engine did some strange things around the same time also
FREEDGUY
Posted: 21 Jan 2022 at 6:17pm |
[QUOTE=DiyDave]Blue oval fluid sprayed on the speedo cables and wiring will fix it!
[/QUOTEYou just keep munching on your gummies
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5276 |
Posted: 21 Jan 2022 at 6:35pm |
It sure is nice having old-fashioned vehicles that don't have computers controlling every little thing.
It makes then super easy to diagnose and fix as well But then there are those that go to the dealer to get a light bulb replaced
FREEDGUY
Posted: 21 Jan 2022 at 6:40pm |
Damn dude, I've not had to go to the dealer "YET" for a headlight change (I assume that's what you meant) but I've heard HORROR stories from 2 different independents getting into "bulb changes"
, NOT pretty for the vehicle owner !!Edited by FREEDGUY - 21 Jan 2022 at 6:40pm |
PaulB
Posted: 21 Jan 2022 at 6:42pm |
no: I wasn't referring to anyone in particular, just giving that as one reason someone would buy a new vehicle. I myself won't buy anything controlled by a computer.
fixer1958
Posted: 21 Jan 2022 at 6:47pm |
Your going to have to accept the fact that truck doesn't like you.
Posted: 21 Jan 2022 at 6:59pm |
NOW THATS FUNNY !!
FREEDGUY
Posted: 21 Jan 2022 at 7:10pm |
Sadly, I came from Dodges previous to this buggy BUT, I will admit that other than the IDIOTIC plugs/coil pack setup and fuel economy, it has been cheaper/mile for repairs
Dave H
Joined: 11 Sep 2009 Location: Central IL Points: 3607 |
Posted: 22 Jan 2022 at 6:30am |
I remember my ole 99 F 250 did that. As Steve mentioned it was a bad speed sensor. As I foggily recall this one was located ON the differential and sorta resembled a cam POSITION SENSOR AND MOUNTED TO THE DIFFY IN THE SAME MANNER. My other sensor problem is my left little finner is numb ans I never know when it hits that caps lock key.
![]() Edited by Dave H - 22 Jan 2022 at 6:31am |
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12420 |
Posted: 22 Jan 2022 at 7:11am |
Is it a digital display or a needle? In this cold, sometimes needles simply stick. I’ve had one or two do that, not your specific vehicle.
FREEDGUY
Posted: 22 Jan 2022 at 7:09pm |
It's a needle display but have been informed that this animals speedo is "electronically" driven ![]() Thanks for the reply though ![]() Edited by FREEDGUY - 22 Jan 2022 at 7:10pm |
Dave H
Posted: 22 Jan 2022 at 8:16pm |
why don't we ask google where that speed sensor is at and change it out?
FREEDGUY
Posted: 22 Jan 2022 at 8:28pm |
How would this help the members with a similar question if I did that?? You "just google it" guys are a real detriment to this site
![]() !! I thought this was a place to ask for "hands-on " questions to be asked for "REAL WORLD" questions ![]() ![]() !! |
DiyDave
Posted: 22 Jan 2022 at 8:30pm |
fixer1958
Posted: 23 Jan 2022 at 5:55am |
Ask your wife, she would probably know where it was.
Jordan(OH)
Joined: 11 Sep 2009 Location: Celina, OH Points: 1580 |
Posted: 23 Jan 2022 at 6:25am |
How did you post this? I’m not going back 50 years for a daily driver. My ‘78 F250 has an ignition control module on the inner fender. |
PaulB
Posted: 23 Jan 2022 at 7:39am |
I guess I need to clarify that I won't buy computer controlled "Vehicles". A "Car" is nothing more than a conveyance to get you from one place to another in a climate controlled zone and a "Truck" is for hauling things. All the latest gimmicks, fads, and fancy crap are why todays prices for vehicles are outrageous. No one NEEDS 90% or more of the stuff that has been put on vehicles nowadays, it's just advertising has brainwashed people into thinking, they have to have it. My car needs no computer to make everything that it has work, it has knobs and levers to control things, same goes for my P/U and big trucks. Good thing to, last fall while returning from a tractor pull a relay in the big truck fried and it lost electrical power. after drifting off the road in a safe place, I was able to turn the screw on top of the injection pump to Manual, start it with a screwdriver and continue home. No way could that have been done with a computer controlled vehicle, I would have ended up with a huge tow bill instead of just needing a $20 relay.
Tbone95
Posted: 23 Jan 2022 at 8:20am |
Yep, but irrelevant. The needle still has to rotate about that pivot point. I have a tractor that does this in the cold. |
AllisFreak MN
Joined: 07 Dec 2009 Location: Minnesota Points: 1619 |
Posted: 23 Jan 2022 at 9:55am |
LMAO |
fixer1958
Posted: 23 Jan 2022 at 11:12am |
If it's what I remember what you have it's probably in the trans tail shaft.
Probably an instrument cluster problem. Not uncommon. Throw a speed sensor at it and see what happens. Probably take 10 minutes depending on how big your belly is. 10mm bolt head. Correct me if I'm wrong, I may be. I'm always up for being wrong.
PaulB
Posted: 27 Jan 2022 at 6:24am |
Page 12> |
