Suggestion(s) removing sickle from ib
KMAG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KMAG Quote  Post ReplyReply Direct Link To This Post Topic: Suggestion(s) removing sickle from ib
    Posted: 21 Jul 2022 at 8:01am
I have a pto driven side sickle mower that I need to remove for engine swap on my ib.
Any suggestions to make the job easier?
For example, unbolt driver's side mower frame mount from channel wrap around frame or just knock out mount's isolator cross-bolt?
Unbolt pass side from "L" angle bracket spring bolt tensioner from wrap around frame to leave it attached to spring or seperate spring from tensioner and leave bracket attached?
Leave sickle in vertical position when unbolting (maybe lifted by engine hoist)?
Thanks.
Edited by KMAG - 21 Jul 2022 at 8:24am
