Styled 1949 Allis WF
Ol case mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ol case mike Quote  Post ReplyReply Direct Link To This Post Topic: Styled 1949 Allis WF
    Posted: 1 hour 52 minutes ago at 5:39pm
On the WF is there a muffler under the hood with a short pipe running threw the hood the hole on the hood is to small for a muffler some images online show a short pipe or was it just a strait pipe I really do not want to cut the hood for the muffler the exhaust was missing when I bought the tractor and head removed
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 5 minutes ago at 6:26pm
The neck of the muffler goes through the hole in the hood from the top. There's not enough room for a muffler under the hood. I have seen drawings in manuals with just a short pipe without a muffler. This way you end up inhaling more exhaust than comfort allows.  The noise may be amusing for short running but not pleasant for a whole day's work in the field. My WF mufflers probably average 2 1/2' in height. The hole in the hood is big enough for the right size pipe. On the WD models with the same engine they made the hole in the hood bigger even though the exhaust goes straight up like on the WF's.
Roger Mn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roger Mn Quote  Post ReplyReply Direct Link To This Post Posted: 54 minutes ago at 6:37pm
at one time you could get a nelson under hood muffler
A-C_220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote A-C_220 Quote  Post ReplyReply Direct Link To This Post Posted: 46 minutes ago at 6:45pm
Yes from factory had underhood muffler same as WC
Sherman Farms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sherman Farms Quote  Post ReplyReply Direct Link To This Post Posted: 16 minutes ago at 7:15pm
My 1949 WF has a under the hood muffler with a strait pipe.
B, C, RC, 3 wc,2 wd,3 wd45, d15, d17, d19, d21, 190, 440, 7040, 918 backhoe, 12 roto balers, 7 60 combines, 40, 66,2 72,90 super, sp100, Gleaner E, F3, 3 L2, R62, and much more
