Styled 1949 Allis WF |
Ol case mike
Topic: Styled 1949 Allis WFPosted: 20 Nov 2025 at 5:39pm |
On the WF is there a muffler under the hood with a short pipe running threw the hood the hole on the hood is to small for a muffler some images online show a short pipe or was it just a strait pipe I really do not want to cut the hood for the muffler the exhaust was missing when I bought the tractor and head removed
Eric B
Joined: 09 Feb 2012 Location: British Columbi Points: 1009 |
Posted: 20 Nov 2025 at 6:26pm |
The neck of the muffler goes through the hole in the hood from the top. There's not enough room for a muffler under the hood. I have seen drawings in manuals with just a short pipe without a muffler. This way you end up inhaling more exhaust than comfort allows. The noise may be amusing for short running but not pleasant for a whole day's work in the field. My WF mufflers probably average 2 1/2' in height. The hole in the hood is big enough for the right size pipe. On the WD models with the same engine they made the hole in the hood bigger even though the exhaust goes straight up like on the WF's.
Roger Mn
Joined: 12 Sep 2009 Location: Preston Mn Points: 109 |
Posted: 20 Nov 2025 at 6:37pm |
at one time you could get a nelson under hood muffler
A-C_220
Posted: 20 Nov 2025 at 6:45pm |
Yes from factory had underhood muffler same as WC
Sherman Farms
Joined: 17 Sep 2009 Location: Centerburg, OH Points: 1682 |
Posted: 20 Nov 2025 at 7:15pm |
My 1949 WF has a under the hood muffler with a strait pipe.
B, C, RC, 3 wc,2 wd,3 wd45, d15, d17, d19, d21, 190, 440, 7040, 918 backhoe, 12 roto balers, 7 60 combines, 40, 66,2 72,90 super, sp100, Gleaner E, F3, 3 L2, R62, and much more
Eric B
Posted: 20 Nov 2025 at 9:59pm |
The first WF we had was a kerosene model and they never had a muffler under the hood as the exhaust came out of the side of the manifold at about a 45 degree angle with no hole at all in the hood for exhaust. With the one gallon gasoline tank under the hood, less than two feet away, it would have been crazy to have an under the hood muffler. Using the belt pulley to run the thrashing machine the manifold turned red from heat, to collect more heat in a muffler under the hood would make no sense, let alone to evaporate whatever gas that was left in the small tank.
