Stupid Question???
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Topic: Stupid Question???
    Posted: 13 Mar 2010 at 9:12pm
Don't ask me how or why,,,,, but is it possible to straighten a twisted connecting rod? It in a tractor that will only be used as a toy, not a everyday tractor. Thanks, Ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2010 at 9:14pm
BTW, its in a MM ZTU!!!! It may have happened removing a stuck piston from a "jug"!!!!
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2010 at 9:17pm
I know that machine shops can/do straighten rods, but I suppose there is a limit to what they can do. Best to take it to a good shop and have them look at it
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2010 at 10:39pm
Yes, They can be straightened.
Find a good engine machine shop.
bigfish_Oh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2010 at 11:49pm
That can't be a stupid question, a stupid question is the one you don't ask.
1941 WC sat for 29 years,started & dynoed 27 h.p.
1957 WD45 Grandpa bought new,factory p.s.,added wfe
1951 WD, factory p.s.
1960 D14 HnMk IV BkHoe 4 sale
2014 HD Tri Glide
2009 GMC CC SLT Dually
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2010 at 8:44am
Depending on how bent it is, some can be straightened. I would think that you should be able to find a used replacement though if worst came to worst....
Steve@B&B
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2010 at 5:24pm
call Rob Ohda at 815-379-2377 for your MM parts needs. He bought out Wilbert Kerchner's MM parts business. He is a very good guy to deal with, and is also an Agco Heritage parts dealer in north central Il. I buy all my parts thru him, yes supporting Agco, but most important, supporting his local business! Ed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2010 at 7:48pm
Thanks for all the help!!! I'm a AC man, and just helping my good friend with this ZTU. Its interesting to see how other companies made their product. MM brakes are a dream compared to AC!! The motor, it was a whole new and strange beast!!!  Ryan
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2010 at 8:11pm
I'm not much of a fan of reworked rods. A hairline crack as the result of bending and straigthening and one day you have a new vent hole in the block.
I saw a rod "refurbished" where the insert had been worn through and the crank left a mark in the rod. It came back from the shop with a nice set of honing marks. But the engine still knocked. I helped take it apart the next time and found the "round" hole for the insert was still ten thousandths out of round. Plenty for a rod knock.
Checking for straight is not trivial, not something you do with a yardstick and a plumb bob. You need STRAIGHT steel shafts to fit in both ends and then a surface place and a dial gauge or better to check those shafts for parallel in a couple directions. Unless the rod can't be had without bends it would not be cost effective to check properly.
Gerald J.
