stuck
jawent View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jawent Quote  Post ReplyReply Direct Link To This Post Topic: stuck
    Posted: 09 Dec 2009 at 1:05pm
I have an Allis D-17 circa 1964 or so.  I had a flat tire and the tractor sat for a good three months before I got around to getting the tire fixed.   Since then the weather has been cold (Minnesota).  When I went to start it (was in neutral), the engine barely turned over and then didn't at all.  When I pushed in the clutch, it fired right up.  When I went to release the clutch, it acted as if it was in gear and bogged out and the engine shut down.  I started it again, with clutch pushed in, but this time when I went to release the clutch I had it it first gear to see if the tractor would move.  Samething happend...engine bogged out and the tractor did not move an inch.  I thought I smelled clutch....also I believe I saw smoke coming from the right side of the engine where you can see the "timing" mark through a hole in the block.  I have also tried to see if towing it in neutral and in gear would free anything up, no luck.  The rear wheels remained locked up.  Any suggestions on what could be happening here.
TomMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2009 at 1:08pm
Could be water in it and now it's froze solid.   Tom
GADinMD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GADinMD Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2009 at 1:14pm
My first thought is that some water got into the drive train somewhere, and now it's ice.  Let's hope so, anyway.
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
-Gordon in Maryland
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2009 at 1:32pm
Very likely you have a mouse nest in the bell houseing.there is a small plate in the underside that pops off , take a look. Gary
I started out years ago with nothing.... after this divorce , I'll be getting most of it back.........
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2009 at 2:51pm
Just had something similar happen to my C. I moved it into the barn a couple of days ago after freeing up the clutch (rust). Tried to roll it yesterday - temp was down in the 20's - and it was locked up tight. As the day warmed up, I could rock it and then it freed up. Found quite a lot of mud (and?) in the brake housing, some water. I figure that the critters were living in there and left a pile behind which froze up when the temp dropped. Hope your problem is as curable.
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2009 at 3:05pm
Had the same problem on an 8N Ford last winter. The trans had enough water in the oil that it froze and the wheels wouldn't turn. I let it set with drain pans under it with the plugs out. I then pointed a salamander heater at it and after about 1/2 hr the ice melted and drained out.
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2009 at 3:10pm
I believe your transmission has water/ice in it
Max(ia) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Max(ia) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2009 at 3:41pm
Had that happen to me once with a C Farmall,  ice.
This page was generated in 0.085 seconds.
