Stubborn WD brake pin
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Topic: Stubborn WD brake pin
    Posted: 13 May 2016 at 12:41am
After 4 years working with Allis tractors, I did my first brake repair with a rusted brake pin. 8.5 hrs of work later and its back together and working. I had the brake pin head twist off and one of the seat bracket bolts twist off. I big mouse nest in the housing did not help anything. I had to get under the tractor with a torch to pull the axle out. Jeeezzzz they should of had a better design!! Here's some pics for your enjoyment/amusement :)
www.awtractor.com
A&W TRACTOR 920-598-1287
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2016 at 5:09am
I think the design is OK, I doubt they figured it would be years and years before people replaced the brakes.
Charlie
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2016 at 6:19am
Congratts Alex!!   As I have said many times before a brake job on one of these (you are only 1/2 done) is the most difficult task there is on one, if the pins don't come right out. BTW before you go near that old WD through some blocking under there, if that jack slips it will come down faster than you can jump out of the way.     Mark
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2016 at 7:01am
Guess what folks.... It's been Years...
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2016 at 7:11am
If you don't get some better safety equipment (bottle jack setting on a brittle cement block), you won't be around for the next four years.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2016 at 7:15am
Good job and yes, sometimes the fast way is not the easy way.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2016 at 7:18am
Taking wheel off final drive would have saved alot of time putting it back togather.      MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2016 at 7:20am
Alex,
Thanks for some additional insight on doing brakes on one of these WD's. Appreciate the pictures!
brenpak View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brenpak Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2016 at 8:28am
That is why I have the professionals do it! Thanks Alex and I will swing around Saturday to pick it up. Sorry to hear it was such a pain!
Oh did you save the mouse? her name was speckles LOL Thanks again...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2016 at 7:05pm
Yes, they probably expected them to get changed more often, and be stored in a barn also, not in the weather. I didn't use cribbing to support the tractor because I like to live on the edge! Seriously, I will use better support next time, thanks guys.
The mouse probably vacated when I tried welding a nut on the pin, so Im sure he is OK.
www.awtractor.com
