stroke |
AC puller
Topic: strokePosted: 17 Dec 2015 at 6:58pm |
How far can you offset grind a wd45 crankshaft and what stroke would that be?
Posted: 17 Dec 2015 at 7:02pm |
If you use Buda (230-262) connecting rods, your stroke will be 4.875". They are 7.375" c to c length versus 7.500" for a stock gas rod.
Gary in da UP
Joined: 13 Sep 2009 Location: EUP of Mi. Points: 1885 |
Posted: 17 Dec 2015 at 7:20pm |
Connecting rod length has nothing to do with stroke. There are only two ways to increase an engines displacement, an over bore with larger diameter pistons, or lengthen the crankshaft throw. |
AaronSEIA
Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2577 |
Posted: 17 Dec 2015 at 7:26pm |
Maybe the good Dr meant to say offset grind and use the Budda rods.
AaronSEIA |
wi50
Joined: 24 Sep 2010 Location: weegieland Points: 1010 |
Posted: 17 Dec 2015 at 8:12pm |
I have a set of Hercules rods that are 8.000" center to center and use a 1.998" crankpin (same as buds). I also have new bearings for them. Would sell the package if someone wants them.
Posted: 17 Dec 2015 at 8:31pm |
The connecting rod length plays a pretty big part in compression distance of the pistons you choose you use. That was the point I was trying to make with the Buda rods being 1/8" shorter than OEM rods. I'm quite aware that the conn rod length having absolutely nothing to do with actual crankshaft stroke.
