Steering Wheel Restoration/Repair?
GT in Indiana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GT in Indiana Quote  Post ReplyReply Direct Link To This Post Topic: Steering Wheel Restoration/Repair?
    Posted: 03 Feb 2010 at 7:02pm
Has anyone figured out a good way to restore a steering wheel that has cracked and or missing plastic coating?  I have used that quick steel putty to fill in gaps, but not exactly thrilled with the results...  I can't even find a decent steering wheel cover that fits properly.
Any thoughts?
THX
GT
1955 WD45 we like to call Ruby
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2010 at 7:07pm
  we carry new steering wheels   what model????  1-800-254-3116 for ordering
   visa  master cards
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2010 at 7:14pm
repairs are basically limited to the steel putty or fiberglass resin. How much time you spend on sanding, and how many coats you use determines the quality of finish... like painting, its all in the preperation... its just time, you got to figure what your time is worth if anything.  ( i work for free... at my house only!).
Brad MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad MI Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2010 at 7:50pm
Like Steve says. Use the epoxy, take your time, fill a little at a time, sand carefully to reshape missing areas. Go slow and prep it to 110% satisfaction before painting. Personally, I would only spend the time on an easy to fix cracked wheel, or an imposible to replace wheel like the early B and RC wheels with covered spokes.
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2010 at 8:20pm
Eastwood sells a kit if it is a rare wheel.  I think the stuff is called PC7 epoxy.
Jack(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2010 at 8:31pm
I have fixed a few and I take my small sandblaster and clean the rust and dirt out of the cracks and then fill them with JB Weld. It dries quick and sands pretty easy. I usually rough it down with 80 grit and then use something finer to finish. Then I prime and paint it and I like to clear coat it. It really doesn't take me all that long to repair one.JP
barky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote barky Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2010 at 8:58pm
I use PC-7 dremel tool and a Jack knive to apply. Moisten your finger to shape,
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2010 at 9:10pm
One of the tricks to doing a repair like you are attempting and making it last goes completely against a person's nature. You have to make it worse to fix it. Cracks must be opened up so the surfaces are fresh and clean. If the steel underneath is rusty it has to go under the blast cabinet. The entire surface that needs repair needs to be roughed up. Loose, and questionable material has to be pried away or cut off. Now that it looks like you trashed  the wheel completely, it is ready for expoxy. I use Devecon but any premium slow cureing expoxy compound will do the trick. Do not use fast cureing, do not use dime store materials. The epoxy is best roughed in for shape when it reaches a semi hard stage when you cut the blobs off with a sharp knife. Itehn go to a die grinder with carbide burr and finaly to sand paper. As for coatings you are pretty well limited to paint. I used enamel on mine and yest it wears off faster than the original coatings but it is cheap and can be reapplied as needed.
Edited by Butch(OH) - 03 Feb 2010 at 9:13pm
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2010 at 9:17pm
I used JB weld to fix the cracks on my D17, but it wasn't long before cracks started showing in other spots.  Replacement steering wheels are pretty cheap now, at least you would not need to worry about it for a long time.
Allis Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Fields Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2010 at 3:18pm
Is  there a crear coat or something like it to protect the new stearing wheels from Going bad after being out in the sun. I mean the black stuff that rubs off onto your hands.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2010 at 4:39pm
New wheels are pretty reasonable. I just replace them.
