steering on Allis B
amosfl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote amosfl Quote  Post ReplyReply Direct Link To This Post Topic: steering on Allis B
    Posted: 08 Feb 2010 at 3:34pm
I have 1 1954 Allis B with adjustable front end. It has gotten very hard to turn to the right . Any suggestions on the problem ?Thanks Amos in Florida
amosfl
Cal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cal Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2010 at 3:55pm
First check to see that you have lube in the steering box, tires inflated properly. Jack it up and see if it steers OK with no weight on it. good luck. I have 2 with adjustable front ends, they don't steer as easily as the arched FE I realy don't know why. Cal in Ct.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2010 at 3:57pm
You might start by jacking it up to take the weight off of the steering. See if you can isolate the problem to one component.
