Steering Cylinder help!!! |
Wlamping
Joined: 08 Feb 2022 Location: Norfolk, VA Points: 10 |
Topic: Steering Cylinder help!!!Posted: 02 Oct 2025 at 2:52pm |
I have an old Army AC Forklift. I can't find the serial # or model # but from the looks of it and the lift data plate it is an ACP-50. It has the 4cyl Continental gas motor and pneumatic tires. I downloaded the Army tech man TM-10-3930-644-14 and all the diagrams and info seems to match up. I blew the steering cylinder and need to rebuild it. The kit referenced is 4906332-4, which is not correct. I ordered the kit and it looks nothing like the pieces I need. Curiously that part# is also listed for the tilt cylinder, which the parts match the pics in the TM. I'm at wits end trying to find the proper kit for the cylinder. Does anyone have any ideas or alt part #s?
Thanks
Wlamping
Posted: 02 Oct 2025 at 5:34pm |
Update, number on the right side of the frame is 107254 and number on the mast is E7TF559 if this helps.
DaveKamp
Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6117 |
Posted: 03 Oct 2025 at 7:15am |
Sounds like someone may have swapped a cylinder at some point?? When I'm faced with this, I carry it into my local hydraulics shop, and have them measure the seal surfaces, and order in the correct size pieces. They have cross-reference books for all sorts of seals, O-rings, wipers, etc.
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42244 |
Posted: 04 Oct 2025 at 8:11pm |
Dave has one idea to solve problem , another is to go to Surplus Center and see what they have to replace present unit with something they have listed .
