Starting Fluid - Good or Bad?
Osage_Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Topic: Starting Fluid - Good or Bad?
    Posted: 21 Nov 2009 at 9:03pm
I've been told ether will cause the engine rings to score the cylinder walls.  Does anyone have any info on this?  I generally put two short blasts into the intake pipe on my HD5G, replace the filter/cover and crank it.  Experiences and recommendations appreciated.
Why is there never time to do it right the first time, but always time to go back and fix it?
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2009 at 9:45pm
we had a international 826 w/ the 'german' diesel, and whenever the temps dropped below 35  we needed a quick shot or two of starting fluid. we did this for years, from brand new to over 6000 hours never had an issue with the motor.
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2009 at 10:53pm
An ether dispenser was an optional equipment on the HD5, from the factory. fact is, a lot of diesels just ain't agonna start w/o it when the mercury drops
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 6:31am
We used to have one of those auto inject ether dispensers on the D-19 D, till the ole coke-head, figgered out how to press the button herself, LOL!  On the serious side, ether is fine for American made diesels, and well made gas motors.  Where you run into trouble is using it on asian diesels, which have extremely thin piston tops.  Half a puff, and your piston tops are floating in the oil of your now disabled engine!
johnkc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote johnkc Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 7:09am
It really only takes half as much ether as a lot of people put down the intake. I read in a manual somewhere that you are to get the engine turning over then give it a shot of ether, about a one second spray. I know this is hard to do when you are the only  person trying to get her going. Have you ever heard that abnormal clacking sound when it starts up? that is when too much ether was used and is what causes the damage. so good battery AND cables and a little whiff of ether and you should be good.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 7:58am
On my HD5G / 2-71 there is 1/4" pipe plug in blower housing , I give it a shot there and then turn it over , that way I bypass the oil bath air cleaner. I drilled the plug and put a roll pin through the square so i have a small handle to remove plug easily.
 It is best to give it that one second shot when engine is turning,   You can get carried a way and lock a engine up with either real easy.  WD40 also works as a starter fluid.
 On 715B with Perkins sometimes in real cold I need to give it several short puffs over a minute or two as it is first starting to get it fireing on all 4
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 10:24am
We have a Ford diesel backhoe/loader that will not start under 40 degrees. I did the same thing as Coke but I had to make a hole with a fitting. I get the engine turning over and have someone give a shot into the intake through the hole I made while the engine is turning over and it always starts right up. If you can get the engine turning over before you put the starting fluid to it they seem to start alot faster from the heat the cylinders are building up from compression.
Most all starting fluids have upper cylinder lubricants in them to help protect the cylinders. Just don't over do it with the fluid.
Edited by Jeff Z. NY - 22 Nov 2009 at 10:46am
realolman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote realolman Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 11:12am
I used to have a john Deere diesel backhoe that developed a hole in the piston.... shop said it was due to too much ether.  Did they know what they were talking about.?.. I dunno.  Did I watch the use of ether from then on?... you bet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 11:17am
You Bet. Just a little dab will do it. Too much and you are asking for trouble.
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 1:26pm
  A few years ago I was hehping start tractors at the auction on a cold winter day. Someone gave a 1030 Case a little too much startins fluied. When they hit the starter with 24 volts to turn it over fast, it turned once and went THUMP. Out came a head gasket and the antifrezze, didnt start. They pulled it through the sale barn, no sale.
 I did Not do it.  Richard
