Starting a 616 restoration
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Topic: Starting a 616 restoration
    Posted: 24 Jul 2014 at 10:49am
here w go folks.  bought the 616 for $70.  mower deck and original 3pt top link for $120.  Just picked up a NOS Onan 19.5hp for $500.  Obviously the onan is not quite configured right so if you can help me identifiy what I need I would appreciate it.
Thanks!
David
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2014 at 10:58am
The hood is sitting in the barn.  the cooling fan is vacuum style, should it be a blower?
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2014 at 11:25am
looks good was the end of the crankshaft tapered had to give $500 for the one we got with bad engine
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2014 at 5:01pm
Are you talking the front stub shaft? It is straight and too large for the clutch/pulley
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2014 at 5:05pm
Also should there be engine mounts or were the Onan base configured differently to raise the motor. Should the fan be blower or vacuum style. What size of pulley should be on the hydro side.
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2014 at 10:55pm
i'm wondering if i just need to do an oil pan swap to the correct style
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2014 at 9:39am
on the 720 we done the engine bolted directly to the frame and the front shaft pto side of engine was1 7/16 if iremember right with asleave to make it go to a clutch with a larger bore when we put the briggs we had to biuld a motor mount 3 3/8 tall to line up with clutch
Toscani NE SD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toscani NE SD Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2014 at 7:44pm
have a machine shop mill the inside clutch radius to your onan crank size,thats what I did to mine
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2014 at 7:00am
Well, the engine looks like my engine other than the flywheel and crankshaft. My flywheel is a large cast iron version half the size of the one that's on your engine. Obviously, the engine is for some other application, but can't see why you couldn't use it with some mod's. Also, my engine was bolted directly to the frame but does have a bolt/nut setup on the bottom of the engine mounting tabs on all four corners located between the engine and frame which lifts the engine a tick. Kinda' strange when I first pulled the engine out this Spring, but its gonna go back in the way it came out. I've was working on and off the engine a while back, and I left the stud/nut setup alone. HTH
Steve@B&B
This page was generated in 0.252 seconds.
