starter WD45
Vinnie/S.D. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Vinnie/S.D. Quote  Post ReplyReply Direct Link To This Post Topic: starter WD45
    Posted: 11 Oct 2010 at 9:49pm
will a starter off a WC Allis chalmers fit on a Allis WD45 I need to know if the one on the WD45 is bad  or not ?
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2010 at 10:43pm
Yes it will bolt up and the stater drive is the same, BUT the starter switch will be on the wrong side. I did this the other way around putting the 45 starter on a WC. I solved the problem by converting to a solenoid & starter button. Kip
