Starter rebuild question
flatcroaker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote flatcroaker Quote  Post ReplyReply Direct Link To This Post Topic: Starter rebuild question
    Posted: 04 Mar 2024 at 12:46pm
Got problem with starter mounted switch. Mine is not making good connection when I pull the rod to starter. Removed switch and under switch there is a copper looking piece that makes starter spin when 12v is applied. Has anyone tried to replace that piece of copper w a stud ( like old ford truck starter) and do away w the switch altogether imo it would last much longer then. Original switch is trouble waiting to happen imo. Let me know I have a good electric shop near me I don’t think he would charge me much. Would need a start button and selonoid and cables should be All parts needed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2024 at 1:13pm
Yes... a GOOD shop could put a stud in place of the copper block.... Might not be something YOU want to do at home... But a shop.. OK.
Post Options Post Options   Thanks (0) Thanks(0)   Quote flatcroaker Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2024 at 2:34pm
Ok thanks
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2024 at 3:24pm
Take it to a local shop.  They can go through the starter to make sure everything is working 100 percent.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2024 at 6:27pm
Good move moving to a solenoid and getting rid of the mechanical switch. Those mechanical switches were great for taking out the Armature with low voltage issues.
Your local shop should be able to remove the pad and install a stud. Have them mount the solenoid right on the Starter. Run some wires and your good to go.
Steve@B&B
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2024 at 9:27pm
I did it on my Model C starter; I just soldered a copper bolt right on top of the lug. So far so good.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2024 at 10:24pm
i did just what steve said  on my wd  a few years ago  ,when you go to drill and tap the case for screws to mount the soliniod make sure it is positioned in the right place , mine had a prestolite with a soliond on it that my grandfather put on when i was  a kid so it was already wired with a starter button.  i ran the 6v prestolite on 12v for long time maybe twenty years  but the 12v delco is much better.
