Starter Motor Crashed & Burned |
Dave(inMA) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Grafton, MA Points: 2399 |
![]() ![]() ![]() ![]() ![]() Posted: 25 Apr 2020 at 9:57pm |
Converted my WD45 to 12 volt system with a solenoid switch to deliver current to the starter motor. That happened a couple years ago. Tractor has had light use since then. At the time, the original 6 volt starter motor was modified to replace the button contact with a post and to incorporate some sort of "shock absorber" to deal with the higher voltage.
Today the starter motor wasn't engaging the ring gear. Here's what I found: ![]() You can see a spot where the casting has been chewed away by the ring gear teeth, so this may have been broken a while. Any thoughts on whether it's better to replace the nose, or should I replace the starter motor with a 12 unit? Thanks for your help! Dave
WC, CA, D14, WD45
I would check timing. Starter spring is usually what 12v breaks. MACK
Sugarmaker ![]() Orange Level ![]() ![]() Joined: 12 Jul 2013 Location: Albion PA Points: 8534 |
Dave,
That does not look good! Thanks for the warning. Old iron, spinning faster. Yea I could see how this could happen! Looks like you need a new starter. I would just find a good used 6 volt and put that in. Also maybe spin the engine by hand and examine the entire ring gear. I would agree that if there are marks from the ring gear that it may have been broken for a while and the nose piece was just dangling in there. Sounds not too good. Let us know how you get this back up and going too. Regards, Chris
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5142 |
Had the starter bee properly rebuilt with 12 volt field coils, it would not hit the ring gear so hard when the starter engages. That extra whump also is hard on the nose casting.
Appreciate the input, guys. Also showed the photo to my brother-in-law who's a retired Cat mechanic. He agreed with Mack - thought that it was caused by the engine kicking back - timing issue. He felt that the break in the casting looked really fresh. Paul, I think it'd take a lot of stress out of its life if I replace the field coils! Update to come.
Dave
Edited by Dave(inMA) - 26 Apr 2020 at 9:31am |
WC, CA, D14, WD45
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24727 |
re: incorporate some sort of "shock absorber" to deal with the higher voltage. I'd like to see the details as to what that is....... 6 or 12, shouldn't matter as to WHY the ringgear was hitting the nosepiece... I KNOW there's a 6V and a 12v version of starter AND ringgear for D-14s... 6v ones all have 'brush inspection bands' on the starters, 12v ones are sealed( NO band). Found that out one day trying to swap starters... dang they get heavy after awhile !! |
1939Dodge ![]() Orange Level ![]() Joined: 18 Jan 2014 Location: Pa. Points: 554 |
talk to SteveNJ before you do anything, then go with his advise.
Jay - I checked my WD45 folder. I have the receipt from the shop that worked on the starter but it doesn't show any details on the "shock absorber".
Dodge - good suggestion - Steve is really helpful on such things!
WC, CA, D14, WD45
Fred in Pa ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9210 |
re: incorporate some sort of "shock absorber" to deal with the higher voltage. Its called doing what Paul said .I will not send a customers tractor out of my shop that dose not have correct field coils in it when changed over to 12 volt .Beside a old starter that has been already wore out with a low voltage 6 battery and throwing 12 volt at it is asking for trouble.
Edited by Fred in Pa - 26 Apr 2020 at 11:12am |
nonetheless ,still dead. If all else fails ,Read all that is PRINTED. |
Is there a way to tell if the field coils are correct by inspection? Thanks!
WC, CA, D14, WD45
Steve in NJ ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Andover, NJ Points: 12007 |
I've always preached here, that if you're running a 12V conversion, its always best to do the Starter motor and change it over to 12V's also. When you send 12V current through 6V field coils, it makes the Starter motor violent. The results are usually cracked nose cones, bent or broken drives, or prematurely worn out ring gears. Looking at that drive on your Starter motor in particular Dave, that looks like the engine kicked back at one time or another and whacked the drive. I would bet a paycheck that the mainshaft is probably bent. Doesn't take much. I've removed bent mainshafts and the Starter motors were still working. Inspect the nose cone and make sure the nose cone isn't cracked, or has a hairline crack in it. Steve@B&B
Interesting, Steve. I noticed that the starter would wobble a bit in its mount when cranking the engine....perhaps because the shaft was bent when it got whacked by the kickback?
I ran across a starter drive called a "barrel drive" - based on the pictures I found, that's the drive that's in my motor. They were mentioned as a good idea if using a 6v starter in a 12v system. Anyone know about them? Dave
WC, CA, D14, WD45
They do have a shock absorber in them. It's the spring on starter drive.
Them old 6v starters will last a long time at 12v. Might as well run them until they are junk, may never have to be replaced. Have saw more noses broke on 6v than 12v, all because of kick back from advanced timing. MACK |
Dave,
If it had (past tense) a little wiggle waggle to it, its bent and is done wiggle waggin'! Probably had a little bit of an issue previously, and the second time around did it in. Barrel drive units are what I use in my 6 & 12V rebuilt's along with a rewound armature. Depends on the model Starter and internal design basically. I see Mack is one of those "let r' rip" kinda guys. LOL!! "Run it till its junk".... LOL!! Steve@B&B
If it ain't broke, don't fix it. lol. MACK
Appreciate the suggestions, guys. I'm going to check several possible causes of kickback before I reinstall any starter! I'd sure like to avoid having this happen again.
WC, CA, D14, WD45
Chucked up the armature in my drill press. You can call it "Wobbling Willy"!! I think it's toast.
[TUBE]1oQrQ8M49lo[/TUBE]
WC, CA, D14, WD45
Dusty MI ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5059 |
Check the distributor advance/retard, If they don't get a few drops of oil once in a while, it can stick in advance and then kick when starting. Remove the rotor and in the hollow shaft is a felt wick that you are to keep moist with oil.
Dusty
Thanks, Dusty. I will do that. I did check to make sure that the shaft was able to rotate freely a bit in each direction.
WC, CA, D14, WD45
A friend of mine would spend all day in his machine shop and FIX 'Willy' to become 'Tommy True'..... Another would spemd a month designing/building an automated machine to fix it in 2-3 minutes.. Me ? I'd buy another starter.....
