Starter for ac 615
Allis7020 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis7020 Quote  Post ReplyReply Direct Link To This Post Topic: Starter for ac 615
    Posted: 15 May 2019 at 8:55pm
Need starter for ac 615 2200 diesel
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2019 at 11:40pm
I rebuilt mine from parts from a White truck gas engine starter . I also bought a starter drive from a rebuilder and found the low priced non rebuildable unit worked better thanthe more expensive unit about 1/2 the price . Unit uses a intermittent bearing plate -
 Mine was on a HD4 diesel unit .
Look in area for a rebuilders shop for generators , starters , alternators - that's where i found parts as when asking at NAPA - I got a blank stare of - we handle automotive parts and not starters ..
"Challenges are what make life interesting; overcoming them is what makes life meaningful."
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis7020 Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2019 at 8:27am
I bought the tractor did not have a starter so I need a replacement if you know any place that could get in besides the new One
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2019 at 9:41am
https://www.ebay.com/b/Tractor-Delco-Remy-Starters-for-Allis-Chalmers/121876/bn_88138528
 Seems some parts and a full sarter might be found here / OR / need to find the actual delco # then start searching . Also if gas or diesel engine as the 2200 came in both flavors
 Might try Steve at B&B on here
Edited by Coke-in-MN - 16 May 2019 at 9:42am
