Starter/Alternator on a "B"...
LBOW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LBOW Quote  Post ReplyReply Direct Link To This Post Topic: Starter/Alternator on a "B"...
    Posted: 15 May 2023 at 9:43pm
This tractor has been converted to an alternator 12v so now it's negative ground. Does that negatively affect the starter in any way besides turning faster? I've been hand cranking but I'm going to want to add a starter soon. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2023 at 10:23pm
I don't know how a B starter compares to a WD 45 starter but my 45 has been on 12V for 42yrs doing fine. It's a 6V starter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2023 at 10:27pm
i have converted several "B" to 12v... Starter dont care one bit.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2023 at 11:11pm
i ran my 6v starters on 12 v for years but i have changed allmy  starters to 12v now much much better no more slamming in hard now and then .   when i do a 12v alternator on somenes tractor i always change the starter to 12v does not matter what color the tractor is
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2023 at 6:50am
As said the starter will work just fine as is, however because of it spinning much faster as you have noticed it just might possible destroy the flywheel ring gear in time. This is not as much of an issue with the tractors with larger engines and flywheels, although the B,C & CA tractors are prone to this, however some will not, why this is, I can't say I myself have a CA that has been just fine on 12 volts for many years and others have needed a couple gear replacements. If your ruins the ring gear, the best thing to do is have the starter rebuilt as a TRUE 12 volt starter, this will slow down the starter speed and prolong the ring gear life.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2023 at 4:06pm
Positive or negative ground - the starter does not care.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2023 at 9:06pm
I always tell our customer's if they're switching over to 12 volts, it's always a good idea to flip the Starter to 12 as well. Bent drives, cracked nose cones and damaged flywheel ring gears are just a few of the common problems when running 12 volts through 6V field coils. This tends to make the starter violent. Besides, who wants to split the Tractor to install a ring gear if you don't have too....  I do a lot of converted Starters for our customer's if interested.
Steve@B&B
bb-customcircuits.com
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2023 at 7:48am
These starters are series wound, meaning the entire current flows through the field and then through the armature; in order to reverse the rotation you need to reverse the polarity of either the field or the armature, but not both. This is not readily done on these units.
Changing from positive ground to negative ground effectively changes the polarity of both field and armature, therefore the rotation remains the same.
On a permanent magnet type starter, switching polarity does cause the starter to run backwards unless you also could turn the magnets around.
