Started Tinkering on the IB
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Topic: Started Tinkering on the IB
    Posted: 30 Dec 2016 at 9:08pm
I'm guessing these aren't correct but just want to make sure this isn't something some of you IB guys have seen in the past. The alternator bracket looks very well made. I mean they even cut it to match the curve of the front support plate on the front of the engine. Also, has anyone seen these little plates on thr outside of the frame before. Guessing those aren't correct. More pics and questions to come.
Can't fix stupid
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2016 at 9:49pm
Not original but nicely done. IIt originally came with a 6 volt generator and a "U" shaped bracket mounted to the bosses on the side of the engine. The patch on the side of the "U" channel is not original either.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2016 at 8:16am
Wow! That bracket could hold up a bridge! That's some Alternator bracket! Talk about HD. Nicely done. The bracket on the other side is an add-on to. Somebody liked to weld.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2016 at 11:27am
Sure would like to have 1 to put on dads 39B with no holes in the block for a genny. Does look good.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2016 at 11:43am
I'd probably part with it Tom.
Can't fix stupid
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2016 at 12:17pm
Is this little bracket assembly anything special or just someones rigging special?
Can't fix stupid
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2016 at 12:23pm
Can someone post a picture of this area on their IB. I have doubts my starter rod bracket/assembly is correct.
Has anyone seen a seat braket set up like this before? Looks really well made. I'm sure the seat isn't right. Just don't know if these earlier IBs had different stuff on them.
Can't fix stupid
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2016 at 12:57pm
This steering arm correct with that bend in it?
Can't fix stupid
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2016 at 1:08pm
Going to rebuild the steering box. Has anyone ever "upgraded" there box with newer version of bearings or bushings to make it steer smoother?
Can't fix stupid
GreenOrange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GreenOrange Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2016 at 1:14pm
Hold up Gentlemen - That generator bracket absolutely IS factory equipment.  This is one of the 260 pre-WWII IB's that were made in 3 runs - one run in each year 1939, 1940, and 1941. If the tractor was equipped with electric starter & lighting from the factory during the 1939 & 1940 production runs, this was the bracket they used.  Not many of these early IB's had the factory starter and lights, so this is a really rare set-up.  In 39 the block didn't have the bosses for generator mounting, in 40 it seems they did have the bosses, but they weren't used.  The 1941 run used the bosses with the more typical generator setup.  Even the electric start torque tube on these pre-war tractors is different than the post-war tractors.  The seat is also factory equipment for the 1940 production run.  There were a lot of differences on these first 260 in comparison with the post-war production, with several differences between the 3 pre-war runs as well.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2016 at 1:53pm
It does have electric start. I think it may have had lights at one time. If I remember right it is a 40. I can get the serial number in a few minutes. Does anyone have a picture of how the generator what setup on these?
Can't fix stupid
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2016 at 2:34pm
Is this seat correct?
Edited by AJ - 31 Dec 2016 at 2:34pm
Can't fix stupid
This page was generated in 0.355 seconds.
