Started one more WD45 diesel engine overhaul |
Page <12 |
| Author | ||
Don(MO)
Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
Posted: 08 Dec 2015 at 6:42pm |
Thanks Chris, You have some nice looking WD's in your barn. The owner is happy with how she is looking too. I was asked to take a lot of shots for the owner to have. |
| Sponsored Links | ||
Don(MO)
Posted: 08 Dec 2015 at 6:44pm |
Not that I know of, the engine came to me in boxes and no electric pump in the pile of parts. lol |
eighty nine
Posted: 08 Dec 2015 at 7:59pm |
Did you ask this because of the oil pressure switch in the oil line ? Kinda got my attention also.
Don(MO)
Posted: 08 Dec 2015 at 8:12pm |
OK, that switch was for a hour meter and after talking to the owner about it I have removed it. I was having trouble understanding the ? about the electric pump that Brain asked bout. lol |
Don(MO)
Posted: 13 Dec 2015 at 3:42pm |
Thought I'd up date work on the WD45 Diesel. I need to take some more shots just forget the camera to the shop. lol
Brian Jasper co. Ia
Posted: 13 Dec 2015 at 3:56pm |
Hour meter... That makes sense. Looking good Don.
Don(MO)
Posted: 15 Dec 2015 at 5:43pm |
I installed the engine today so here's some more shots. The parts boxes are starting to empty out, but lots more work to go before she is a runner again.
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7531 |
Posted: 15 Dec 2015 at 9:34pm |
Very impressive work!
Orange Blood
Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
Posted: 16 Dec 2015 at 10:25am |
As always Don, GREAT WORK!!! But I really think you can have her running by Noon tomorrow.
Still in use:
Don(MO)
Posted: 16 Dec 2015 at 11:43am |
Thanks for the kind words guys.
I'm not seeing it run for sometime, I still need to rebuild the Diesel trans/rear end that came in the tractor and change it out with the gas trans/rear end that's in it now, clean and repair the fuel tank and a long list of little things before she fires up from it's long nap of 10+ years of retirement; And I have three WD/WD45, three D14's and a engine overhaul on a D19 Diesel tractor all needing some of my time too.lol So I work on one tractor tell I need parts and just on one of the tractors that's parts have came in. |
Brian Jasper co. Ia
Posted: 16 Dec 2015 at 12:05pm |
Somebody had a WD45D rear end for sale in the classifieds...
Tim NH
Joined: 16 Oct 2012 Location: Lancaster NH Points: 1125 |
Posted: 16 Dec 2015 at 5:27pm |
Your work looks flawless. You have spoiled everyone in your area. When are you going to move up here. The summers here are not as hot. lol Tim
220allis
Posted: 17 Dec 2015 at 9:34am |
Don were looking for series 4 d17 diesel how much do you think I should budget for an an overhaul if my head and bookcase are good trying to find original paint and tire tractor but want it to start and run clean also would you be interested in doing the work
220allis
Posted: 17 Dec 2015 at 9:36am |
Block not bookcase
Don(MO)
Posted: 17 Dec 2015 at 12:16pm |
I sent you a PM. ![]() |
Don(MO)
Posted: 12 Apr 2018 at 8:47am |
This is a old post of mine with the pics working again.
EsoxAllis
Posted: 10 May 2018 at 8:54am |
Hi, I'm new to the forum and have a 1956 WD45 Diesel which needs some work. She runs, but has lot's of leaks (hydraulic rams, under the clutch housing, etc.). Hand cluth does not work -- so I'm guessing I have lots to do with new seals, clutch plates, and the like. My question for you guys is advice about the engine. I'm quite certain diesel fuel is getting into the crankcase -- and have seen on this forum that that can come from a couple different issues (o-ring/seal) in the fuel pump. I may be able to tackle that. However, I'm wondering about a complete engine rebuild -- and am not sure I'd want to try that. Anyway, here's my questions:1) Can I (should I) leave the engine alone and just go after the the rest of the tractor? Or, would that be short-sighted/folly. As menetioned, it runs, but smokes a lot -- especially at first start-up. The smoke color is not black, but not white either -- I'd say ~ grey. The smoking comes down after the tractor warms up, but never really goes away -- and comes back again fairly heavy under load (road gear). To me, it does not seem to have a lot of power, but I've never actually pulled with it either. As well, I believe some of that crank oil w/ diesel (or diesel from soemwhere else) is getting into first clutch housing -- is that possble (main bearing issue)? I say this because last summer it started leaking (dripping) from the inspection port/thumb-screw under the clutch housing -- and I'm talking a couple gallons over a number of months now. This oils is very thin as smells like diesel to me.
2) If the engire needs to be rebuilt. Is there someone who still does this? And/or can all the needed parts still be found if I or a local mechanic were to give it try? Thanks for any advice/insights you can offer!
Jim Hancock
Joined: 11 Sep 2009 Location: EL Reno, Ok. Points: 1112 |
Posted: 10 May 2018 at 9:43am |
Welcome aboard Esox Allis!
I can't answer your questions, but somebody will come along and give you some insights before too long if they're not out in the fields or shop by now.
How blessed we are by HIS GRACE!
farmtoybuilder
Joined: 11 Sep 2009 Location: Dresden,Ohio Points: 1457 |
Posted: 10 May 2018 at 11:48am |
Fantastic Work! Love the pictures and all your Knowledge!!!!!!!!
Don(MO)
Posted: 10 May 2018 at 6:35pm |
Welcome aboard, you will find a lot of good people on here. This is a good post with your long list of ?'s it might be best for you to just send me a PM and I will send you my phone number.
Edited by Don(MO) - 11 May 2018 at 9:57am |
Michael Crowe
Joined: 11 Sep 2009 Location: Kansas City Points: 1726 |
Posted: 10 May 2018 at 9:27pm |
Don are you starting yet another 45D? If anyone wants to hear a sweet sounding D19D give me a call, he did a beautiful job on mine!
Page <12 |
