Started one more WD45 diesel engine overhaul
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2015 at 6:42pm
Don,
 Looks fantastic! Someday I need to do a Allis engine. You sure do make it look easy!
Thanks for posting the nice clear pictures of you work as you progress.
Thanks Chris, You have some nice looking WD's in your barn.
The owner is happy with how she is looking too.
I was asked to take a lot of shots for the owner to have.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2015 at 6:44pm
Originally posted by Brian Jasper co. Ia Brian Jasper co. Ia wrote:
Looking good Don. Was someone using an electric lift pump on that engine?
Not that I know of, the engine came to me in boxes and no electric pump in the pile of parts. lol
eighty nine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eighty nine Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2015 at 7:59pm
 Did you ask this because of the oil pressure switch in the oil line ? Kinda got my attention also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2015 at 8:12pm
OK, that switch was for a hour meter and after talking  to the owner about it I have removed it. I was having trouble understanding the ? about the electric pump that Brain asked bout. lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2015 at 3:42pm
Thought I'd up date work on the WD45 Diesel. I need to take some more shots just forget the camera to the shop. lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2015 at 3:56pm
Hour meter... That makes sense. Looking good Don.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2015 at 5:43pm
I installed the engine today so here's some more shots. The parts boxes are starting to empty out, but lots more work to go before she is a runner again.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2015 at 9:34pm
Very impressive work!
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2015 at 10:25am
As always Don, GREAT WORK!!!  But I really think you can have her running by Noon tomorrow.Wink
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2015 at 11:43am
Thanks for the kind words guys.
I'm not seeing it run for sometime, I still need to rebuild the Diesel trans/rear end that came in the tractor and change it out with the gas trans/rear end that's in it now, clean and repair the fuel tank and a long list of little things before she fires up from it's long nap of 10+ years of retirement; And I have three WD/WD45, three D14's and a engine overhaul on a D19 Diesel tractor all needing some of my time too.lol So I work on one tractor tell I need parts and just on one of the tractors that's parts have came in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2015 at 12:05pm
Somebody had a WD45D rear end for sale in the classifieds...
Tim NH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2015 at 5:27pm
Your work looks flawless. You have spoiled everyone in your area. When are you going to move up here. The summers here are not as hot. lol Tim
220allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 220allis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2015 at 9:34am
Don were looking for series 4 d17 diesel how much do you think I should budget for an an overhaul if my head and bookcase are good trying to find original paint and tire tractor but want it to start and run clean also would you be interested in doing the work
Post Options Post Options   Thanks (0) Thanks(0)   Quote 220allis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2015 at 9:36am
Block not bookcase
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2015 at 12:16pm
I sent you a PM.Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2018 at 8:47am
This is a old post of mine with the pics working again.
EsoxAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EsoxAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2018 at 8:54am
Hi, I'm new to the forum and have a 1956 WD45 Diesel which needs some work.   She runs, but has lot's of leaks (hydraulic rams, under the clutch housing, etc.).   Hand cluth does not work -- so I'm guessing I have lots to do with new seals, clutch plates, and the like.  My question for you guys is advice about the engine.   I'm quite certain diesel fuel is getting into the crankcase -- and have seen on this forum that that can come from a couple different issues (o-ring/seal) in the fuel pump.  I may be able to tackle that.  However, I'm wondering about a complete engine rebuild -- and am not sure I'd want to try that.    Anyway, here's my questions:
1)   Can I  (should I) leave the engine alone and just go after the the rest of the tractor?  Or, would that be short-sighted/folly.   As menetioned, it runs, but smokes a lot -- especially at first start-up.   The smoke color is not black, but not white either -- I'd say ~ grey.   The smoking comes down after the tractor warms up, but never really goes away -- and comes back again fairly heavy under load (road gear).    To me, it does not seem to have a lot of power,  but I've never actually pulled with it either.   As well, I believe some of that crank oil w/ diesel (or diesel from soemwhere else) is getting into first clutch housing -- is that possble (main bearing issue)?   I say this because last summer it started leaking (dripping) from the inspection port/thumb-screw under the clutch housing -- and I'm talking a couple gallons over a number of months now.  This oils is very thin as smells like diesel to me.
2) If the engire needs to be rebuilt.   Is there someone who still does this?   And/or can all the needed parts still be found if I or a local mechanic were to give it try?
Thanks for any advice/insights you can offer!
Jim Hancock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2018 at 9:43am
Welcome aboard Esox Allis!
I can't answer your questions, but somebody will come along and give you some insights before too long if they're not out in the fields or shop by now.
How blessed we are by HIS GRACE!
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2018 at 11:48am
Fantastic Work! Love the pictures and all your Knowledge!!!!!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2018 at 6:35pm
Welcome aboard, you will find a lot of good people on here. This is a good post with your long list of ?'s it might be best for you to just send me a PM and I will send you my phone number.
Edited by Don(MO) - 11 May 2018 at 9:57am
Michael Crowe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2018 at 9:27pm
Don are you starting yet another 45D? If anyone wants to hear a sweet sounding D19D give me a call, he did a beautiful job on mine!
