Stainless steel angle iron
200Tom1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200Tom1 Quote  Post ReplyReply Direct Link To This Post Topic: Stainless steel angle iron
    Posted: 01 Mar 2022 at 7:05pm
Anybody have any idea where a guy could get about 12'. Must be 2"X 3" 3/16 thick. I have seen some sites with unpolished stainless at $800.00 for each piece. I thought that was quite high.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2022 at 7:15pm
you might call these guys... "MOST" angle iron sold has equal legs...
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2022 at 7:26pm
Ryerson can get 2 x 3........ call for price
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2022 at 5:04am
McMaster Carr may have some, but 12 feet maybe not??
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2022 at 5:33am
Try Shapiro Supply in St. Louis. They will ship small quantities and are priced pretty fairly.
Edited by Codger - 02 Mar 2022 at 5:34am
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2022 at 5:42am
I don't know if they've changed but, if I remember correctly, 6 ft used to be their limit
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2022 at 5:53am
do you actually NEED SS ,those dimensions and a 12' single piece ? If so..the you'll have to pay.
Any chance you can use an alternative ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2022 at 9:00am
Most places will have 20 ft lengths or so... You could buy 12 ft, but they normally sell 5-6 ft as it is easier to SHIP.... If you want 12 ft ONE PIECE, look local, or it will be shipped on a Big truck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200Tom1 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2022 at 8:09pm
Guys it has to be cut into 2" lengths with 2 holes drilled in them.   Sorry I didn't make that clear.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2022 at 11:19am
Hmm - drops are sometimes cheaper - but 12' of drops of 2" each if they cut is going to be expensive .
 Son just got steel on Thursday  - what he ordered last year of same weight and size is now 3 times the price . , most was 2" x 2" x 20ft box tube .Then they charge a delivery fee if order is not over $800 - that was no problem as the bundle I unloaded was $2,500
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2022 at 11:26am
re: 2" lengths with 2 holes drilled in them.
well that is a different kettle of fish !!!
find a local fab shop, dumpster dive(with permission)
if not, find online in small sections, then have a shop punch holes and cut to 2"
'HAS' to be stainless ? if so, what grade(that'd be a spec to....)
Trawler II View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trawler II Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2022 at 2:40pm
Not sure if you have any wiggle room on your dimensions. If you do you might look at a product called Unistrut. They make SS angle clips with punched holes. Type 304L stainless. You may be able to modify or adapt to suit your requirements.
If not a metal fabricator should be able to cut and punch the angle to your specs.
800-586-4787 Try this number, distributor in Ohio. With your quantity they should be able to ship UPS small package.
Edited by Trawler II - 05 Mar 2022 at 3:15pm
"Most people find it easier to believe a simple lie, than the complex truth"
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2022 at 4:40pm
Try speedy metals online. Best i can tell 6 2 ft pieces is 300.00.plus shipping
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
This page was generated in 0.227 seconds.
