Stabilizing 3 point conversion sway arms, D14
schangfleeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote schangfleeman Quote  Post ReplyReply Direct Link To This Post Topic: Stabilizing 3 point conversion sway arms, D14
    Posted: 15 Feb 2022 at 3:01pm
I just picked up a D14 from my uncle's walnut orchard that I'm hoping to convert for use on my vegetable farm.
It has the SC to 3point conversion hitch already on it but the lift arms have no way of locking or stabilizing to become rigid. I'm wondering if anyone has any ideas how to modify the lift arms with more modern and adjustable stabilizer chains/turnbuckles so I can use the tractor to do more accurate work like seeding and cultivating where I need the implement to track straight.
Thank you
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2022 at 3:26pm
I would "X" cross a pair of chains from the drop part of the conversion.  I'm thinking that the blade or one of the other snap coupler implement had like 1 inch flat bars to do this.
Den
Own 4 wheel 20, 2-5015, 5020 and associated equipment and 2 electric forklifts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2022 at 3:36pm
yes, Den is right ! My rear blade(oxnard) has a 'cross of flat bars' with 2 sets of holes.1 for D-14, others for CA
chains and turnbuckle  in an X might work  ?
one of those need to see a picture to advise.
I have THREE different SC<>3PT adapters
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2022 at 3:45pm
Yours looks like this ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2022 at 3:49pm
Or do you have individual arms on a 3rd member connected to the SC, like this ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote schangfleeman Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2022 at 9:36pm
This is the kit I have. There is a frame that goes between the two arms that limits the sway a bit but there is still lots of play even with that one chain. I'll try to snag a picture when I'm back at the farm tomorrow.
Edited by schangfleeman - 15 Feb 2022 at 9:37pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2022 at 9:50pm
those two little chains and the bracket are suppose to bolt below the rear housing and help reduce some side swing..
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2022 at 6:24am
If you have the two chains you can choke up on the links at one or the other end. Just check the lift height may be limited.
Ferguson's and Ford's have metal straps to go from pin brackets under the fender mounts down to the implement pin ends on both sides.
Modern tractors do the same but use turn buckles.
You can likely find a couple options rummaging around at tractor supply.
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2022 at 7:58am
I have a question about that first design pictured. That tubular tie bar, could that hit
(and a bend)  a PTO drive shaft? What is it's purpose?
The sway chains are vital to keep the 3pt arm from hitting the tires.
With no implement mounted check that the arm can not touch the tire lugs.
Grab it, lift it up and down, while pushing it outward.
And check that in the full up position it is not bound really tight.
I only ever use the sway chains for mowers, somtimes. Having your implement being able
to swing away from rocks and posts could help prevent bent and broken equipment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2022 at 8:48am
Brian, the cross bar does "some" structure in tieing the two arms together to keep side movement to a minimum... And it probably keeps the arms from hitting the tires , as you said.......... and YES, you have to probably remove if you are using the pto shaft... OK for blade / disc / etc.
