ST35/MF1533 pto clutch |
Post Reply |
JohnCO
Orange Level Joined: 11 Sep 2009 Location: Niwot Colo Points: 8992 |
Posted: 15 Aug 2019 at 11:38pm |
Mine is still red but someday it will turn orange... Anyway, when I brushhog heavy weeds, the pto slows down and stops until I lift the mower or get into lighter material. I assume the clutch is slipping but being an electric engage system I'm wondering if it is something to do with not enough electric power to keep the pto going. Any ideas?
Allis Express participant |
DiyDave
Orange Level Access Joined: 11 Sep 2009 Location: Gambrills, MD Points: 50331 |
Some EC's have an air gap adjustment... I'd check that first...
JohnCO
Thanks Dave, how do I do that? |
DiyDave
Keep in mind that These procedures are different for each clutch in question, and that these clutches can be completely worn out , and adjustment can be worthless, if there is too much wear...
Here's a video on 2 of the most popular EPTO clutches. He also has linked to other videos, that may be helpful... [TUBE]hZNILWqmcEg[/TUBE]
JohnCO
Thanks Dave, but my tractor has an internal pto clutch to run the rear pto. This is a 35 hp tractor with a normal looking rear end housing.
DiyDave
That number sounded a little big, for a lawnmower type clutch. Yours prolly has worn out the lining. I'd go to agco, and see what is involved in the service manual... Good luck
On doing a little more research, using the tractor # and the term pto clutch repair, your tractor has a electricaly activated hydraulic pressure activated pto clutch. and the activation has a fuse, and is tied in with the seat switch. Lotsa stuff that can be checked, switches, fuses, hyd pressure , etc... Edited by DiyDave - 19 Aug 2019 at 4:52am |
Mike R. in Maine
Bronze Level Joined: 12 Sep 2009 Points: 65 |
Look at the very bottom of the transmission, you'll find a small steel line that applies pressure to your pto clutch. A lot of them get hit and pinched / bent and causes the clutch to get less than full pressure.
JohnCO
Thanks for the advice, will check it out. The tractor was used since new to pull irrigation pipe trailers and the PTO and 3 point were never used. I bought it out of Idaho several years ago. The PTO seems strong but then when the mower hits some tall weeds it just slows down and sometimes stops. If I lift it up it will start running again and work fine as long as it doesn't have to work too hard. Humm, kinda like me...
JohnCO
Unfortunately the tube under the tractor looks like new, no dents or kinks. Any other ideas? I changed the oil and filter last year but it only has 18 hours on it since then and is stored in a shed. |
DiyDave
Does it have a suction screen, for the hyd pump, that could be blocked?
Post Reply | |
