spreading litter w/ 7080 |
SCPAAndy
Joined: 05 Dec 2009 Location: East Berlin, PA Points: 209 |
Topic: spreading litter w/ 7080Posted: 07 May 2010 at 10:08am |
The website is out of date- this one is a 5290 the smaller if u can call it
that of the 2 vertical beater models. The thing I don't like about the side slingers is the spread pattern bc they don't spread as even and the augers will allow the pen pack to bridge up and not feed nice but to each his own- plus a 40' + spread pattern really covers acres quick |
Jordan(OH)
Joined: 11 Sep 2009 Location: Celina, OH Points: 1572 |
Posted: 07 May 2010 at 9:25am |
Is that a 3290 or 3440? or whatever the big one is?
Nathan
Posted: 07 May 2010 at 9:10am |
The knight side slingers are excellent machines. When it comes to hydra push spreaders I believe H&S builds the best one alot of little differences over other brands that make it easier to work on and alot less likely to have problems due to the placement of the drive gearboxes. Just my thoughts though. |
35WC 37WC D-10 D-12 D-14 D-15 D-17series 1 (2)D-17IV D-19 CA RC Unstyled WF GLEANER E 416H 314H 712H 716H
SCPAAndy
Posted: 07 May 2010 at 8:25am |
When hauling dry litter Weights are roughly 7-8 ton like what u see loaded now and for wetter pen pack 14-15 ton. As far as compared to side slingers there is no comparison- the hagedorn does a very even job and spreads anything from lime, litter, pen pack to very sloppy manure
klinemar
Joined: 14 Sep 2009 Location: Michigan Points: 8064 |
Posted: 07 May 2010 at 7:01am |
After checking the Hagedorn website I find my estimate was off by 150bu. The spreader should hold 550bu. struck which is still a lot of weight,solid manure weighs approximately 77.4 lbs. to the bu. with the spreader holding 550 struck the weight of the manure would be 21.28 ton. my source is Iowa State University tips for spreader calibration.
klinemar
Posted: 07 May 2010 at 5:22am |
Looks like the spreader holds about 700 bu. struck.Tell us if I am correct.
klinemar
Posted: 07 May 2010 at 5:20am |
How do you like the hagedorn spreader for manure?Some here had John Deere Hydrapush and did not like them.I always had Knight slinger spreader worked great except for pen packed.A spreader that big will work a 7080 just pulling it down the road also a big tractor does not bounce as bad on the road and stops better.I have seen farmers try to pull big spreaders with smaller tractors and have disasters like broken drawbars,rollovers, and being pulled off the road when getting over for on coming traffic.Manufaturer's are now require to put hydraulic brakes on the big spreaders for safety.
Eldon (WA)
Joined: 11 Sep 2009 Location: Spokane, WA Points: 7765 |
Posted: 06 May 2010 at 11:19pm |
How many ton in a load? Do you really need that big of a tractor for that spreader?
ALLIS EXPRESS!
This year: |
Harvey/pa
Joined: 11 Sep 2009 Location: York Co. Pa. Points: 1031 |
Posted: 06 May 2010 at 9:15pm |
WOW, looks great Andy! You could do restoration work when you have nothing else to do. Tell Dad I didn't forget, I will get the "rest of the story" someday...Harvey
AllisFreak MN
Joined: 07 Dec 2009 Location: Minnesota Points: 1594 |
Posted: 06 May 2010 at 8:17pm |
Sweet tractor. Probably not so sweet aroma.
Don(MO)
Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
Posted: 06 May 2010 at 8:03pm |
I'll bet you need that big 7080 to pull the load of well stuff around the field.
Nise looking tractor!
Don
SCPAAndy
Posted: 06 May 2010 at 6:27pm |
