Spray for garden??
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: Spray for garden??
    Posted: 25 Feb 2024 at 10:19am
Crazy question, is there a spray to control weeds in a garden that wont hurt plants? Kinda sounds off to use spray with things a person will eat , but just curios;  I may have to shine up the old hoe !
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2024 at 10:25am
Black plastic works well in cucumbers, peppers, squash, tomatoes, etc., that are planted in hills or transplanted as plants.
After emergence, I have used Preen. Preen prevents emergence, so make sure your plants are up before using. Preen is not a spray. It is granules that you spread by hand.
Edited by WF owner - 25 Feb 2024 at 10:29am
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2024 at 10:40am
what is a 'weed' ?
some 'weeds' hate 2-4d, if you can buy it........
heavy layer of mulch ( NOT black walnut !!!! ) works well
dkattau View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dkattau Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2024 at 12:32pm
PREEN works good as a pre-emerge herbicide.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dkattau Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2024 at 12:33pm
what is a 'weed' ?
You won’t have a tomato left if you use 2,4-D.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2024 at 3:18pm
Originally posted by dkattau dkattau wrote:
what is a 'weed' ?
...or any other "broadleaf". Grasses should grow well!!!
Edited by WF owner - 25 Feb 2024 at 3:18pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2024 at 3:39pm
I can't buy 2-4d, guv law...unless I'm a golfcourse........
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2024 at 5:26pm
what is a 'weed' ?
Only if you get the 2, 4-D on the tomatoes.  It has no soil activity, unlike the other broadleaf herbicides.  If the tomatoes are small enough to fit under a 5 gallon bucket (as a shield), then you can spray most any non soil active weed killer, and not kill the shielded plant.  Just wait till the spray dries, then remove the bucket(s), and you're done.  You will still have to hand weed around the desirable plants...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote dkattau Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2024 at 5:58pm
what is a 'weed' ?
2,4-D drifts. It doesn’t need to sprayed directly on tomatoes to kill them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2024 at 6:32pm
In any case, Preen works well for all transplanted plants.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2024 at 8:33pm
what is a 'weed' ?
Not when there is a bucket covering the plant, till the spray has dried...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2024 at 6:50am
what is a 'weed' ?
I haven't used 2-4D for years and never used it near something that I didn't want to control weeds in, but IIRC, 2-4D is not a "contact" herbicide (like Roundup), so wouldn't there be some migration in the soil? How would you know how close you could apply 2-4D?
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2024 at 12:19pm
In theory 2-4D can drift just like Banviel or the newer formulations for GM soybeans and cotton. I have sprayed a lot of 2-4D over the years and never seen it drift, just lots of little skips where I could have used a bit of drift.
From what I read Banvel can volatilizes as much as 2 or 3 days after the spraying, again I have not witnessed it myself.  But much harder to keep in one place than 2-4D is.
Even here in Chinese colony of California there is a watered down form of 2-4D you could even find in the Walmart garden section.Wink Well I was told Wally had it have not been in one in years. But I know the local farm supply places have it yet.
Being systemic action chemical and soil activity are not the same thing. But I don't know about 2-4D if could have a very limited soil activity, but nothing that last for more than a week or 2 for sure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2024 at 4:47pm
To a certain extent all oil based herbicides can volatize.  Volatility can be decreased by not spraying periods of high temperature. Spray in the early morning or late evening, with the desirable plants covered with a bucket or plastic cover. Remove the buckets or cover after spray has dried. If you leave covered too long in the sun, you risk sun burn or over heating.  I would not spray after temps start hitting 55 degrees at night.
Roundup is a better choice after early spring, it also has little if any soil activity.  Best is Preen or a similar pre-emergent, BEFORE the weeds sprout.Wink
