Spray chrome |
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7639 |
Topic: Spray chromePosted: 29 Jan 2022 at 9:18am |
Has anyone tried having this done rather than chrome plating? The chrome pieces on the B110 I am restoring are covered in surface rust, so I have been leaning towards spray chrome as a more affordable alternative. However I have heard that it can flake off pretty easily and does not have the same mirror finish as chrome plating. What are your experiences? Many thanks!
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8982 |
Posted: 29 Jan 2022 at 9:28am |
Polish and wax would be better than fake chrome. You know the only real answer i$ to get it rechromed
plummerscarin
Posted: 29 Jan 2022 at 10:04am |
X2. I think spray chrome is just extra bright silver paint. Having said that, I cleaned up the chrome stadium light bar on the 7045. The corrosion was worse on the top side so after cleaning, polish and wax, I sprayed the top side with the "chrome" feathering to the real chrome. Looks good from the ground |
dee_veloper
Posted: 29 Jan 2022 at 1:46pm |
If it isn't too terribly rusted, you can polish it up with light oil and 1500 grit sandpaper. I did that on my B110 and it turned out very nice.
Don't confuse my personality with my attitude.
My personality is who I am. My attitude depends on who you are. |
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5276 |
Posted: 29 Jan 2022 at 3:29pm |
I've seen many things done with a "chrome" powdercoat. Like all powdercoat, it looks good to begin with and over time if it gets chipped or has a defect anywhere it will flake off. With most anything there is no substitute for doing a job right.
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25258 |
Posted: 29 Jan 2022 at 4:01pm |
Have you checked local motorcycle places for chroming ? Real stuff is 'triple plated' , copper-nickel-chrome.... $$$ Prep is 99.44% of the job. Rest is 'easy'....
DSeries4
Posted: 29 Jan 2022 at 7:58pm |
It would take a ton of work to get any shine out of this grille. The
support for the arm rests is worse. Thinking about it over the day,
re-chroming would be the way to go. Could also get the D21 grille
polished at the same time! |
