Splitting Wd45, what all should I replace |
JTS
Topic: Splitting Wd45, what all should I replacePosted: Yesterday at 3:51pm |
Finally found someone to help me with splitting my Wd45. I'm assuming this has never been done on this tractor before and much should be replaced based on everything else I've done so far. Anyone willing to chime in and provide me with a good list of what I should definitely replace or check while it's split since this is such a hassle and I don't want to have to do it again in my lifetime?
Posted: 20 hours 12 minutes ago at 6:50pm |
Why are we splitting it?? And where are we splitting it ??
JTS
Posted: 7 hours 48 minutes ago at 7:14am |
Because I have a hydraulic leak coming into the bell housing from that seal between the two, along with a few other hydraulic seals I want to replace. I also removed the inspection plate under the bell housing and founds shards of metal so likely need to replace the throw out bearing too.
Posted: 7 hours 41 minutes ago at 7:21am |
So, you are basically looking at a clutch shaft seal replacement (the oil leak) and possibly a foot clutch/pressure plate/throwout bearing/pilot bearing replacement as well. Engine removal to do this isn't that tough. Remember, overfilling the hydraulic compartment will cause hydraulic oil to leak into the flywheel area. The vent for the hydraulic compartment actually goes into the flywheel area.
Edited by DrAllis - 7 hours 21 minutes ago at 7:41am |
