Splitting Firewood
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Topic: Splitting Firewood
    Posted: 23 Nov 2018 at 6:14pm
I have a really big Black Gum (Tupelo) Tree I could cut for firewood. Question is Will it Split?   Sweet Gum don't split worth a hoot.  Piss Elm?   Forget it. Not Splitable at all.
 Right now I'm splittin Post Oak. Really any Oak or Hickory splits good.
      Never had any Black Gum to play with.     If it can't be split I will not cut it down and buck it up
acd17toy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd17toy Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2018 at 6:27pm
With my wood splitter there are some types of wood that do not split, but with a sharp wedge it will cut thru most any thing including knots. So yes with a sharp wedge it will cut or split any type of wood
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2018 at 7:31pm
like acd says...have a sharp wedge and let it cut on thru. I have a 3 pt splitter, has a Cat hyd cylinder on it and hooked into the hyd's of my 180D. I've never found anything it won't split or cut thru yet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2018 at 7:34pm
I need to pull my splitter out of the barn, neighbor 'Borrowed' it and bent the crap out of it so I found as he was trying to over weld the screw up. I had him stop, he will not ever 'borrow' from my equipment again. I need to repair it and set it up for going back to my Brother In Laws place as that is where I built it for. We do not have wood heat here at all.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2018 at 9:09pm
We've split piss elm.  Most will split but there are the spiral pieces that just go in the camp fire or on the burn pile.  I don't think we have any gum trees up here so I can't help you on that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2018 at 9:20pm
I googled Splitting Black Gum .    Answer I got was,     Don't even try.  It don't split.  Stick to straight grain woods if you want to burn split wood in your wood stove or fireplace insert.
Edited by Ken in Texas - 23 Nov 2018 at 9:22pm
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2018 at 10:04pm
I cut piss elm and stack it off the ground for 2 years, it doesn't burn too bad then. This reminds me to fill the darn woodrack tomorrow. Ol Shameless is supposed to dump on us Sunday. That's not all bad maybe some of my freeloading in laws won't be able to get here for dinner on Sunday, but don't take any bets on that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2018 at 6:16am
OK, I had some 'narly' tree here and it split ok. MY 'trick' is to cut into 10-12" long logs, then the electric splitter will do it's thing. The shorter log allows the cutting wedge to follow the grain.
I cut to 12" cause I only burn in my outdoor firepit.Smaller logs fit the truck rim real nice !
Electric splitter, a friend dropped off, works great..once you bypass one of the safety interlocks. It's fast enough for me, clean, quiet,no mess either !
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2018 at 7:55am
I had a splitter with a 8 hp Briggs and a two stage pump.
Lots of times piss elm and sweet gum made  it drop down a  stage, but that sharp wedge just kept moving.
i spose you already have a splitter, hope it is not a puny one.  Wink
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2018 at 5:10pm
Dad got a new chainsaw when i was a teenager and i wanted to try it out .Cut a black gum and cut up in blocks about 15 inches .Let dry couple weeks and one day dad split blocks with chainsaw.Let dry some more and split  with godevil. Made good wood.
This page was generated in 0.447 seconds.
