splitting CA
CAdon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAdon Quote  Post ReplyReply Direct Link To This Post Topic: splitting CA
    Posted: 15 Mar 2012 at 9:26pm
final question for the night:
need to split my CA because previous owner disabled foot clutch cuz he "heard some clanking in there".  for my limited use i relied on the hand clutch as he did.
i HAVE read all the safety warnings here and definitely will follow them (including adequate support of engne half to prevent rollover).
looks to me like i'll need to remove the suspended framework (and what's that for btw?) and circled the location of known (guessing here) nuts/bolts to allow it to split. just asking if there are more... i DO hate surprises dealing with heavy machinery...
i have a two week vacation coming up in a week (high school teacher) & plan to do "the
great adventure" then.  while it's open i plan to replace the whole clutch kit.
cannot tell you how eager i am do do my first "major project" on this.  and now realize i MUST find a B to run while i'm working on the CA... and vice versa.
do i really need 2 AC's on a little 5 acre plot?  answer: at LEAST 2!! ez to catch orange fever, isn't it...
Edited by CAdon - 15 Mar 2012 at 9:28pm
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2012 at 9:38pm
Well first off that cultivator and frame has to come off (more reason to sell it to me)...then you will see two more bolts behind it that match the top bolts you circled. Remove the gas tank and fuel line. Then the throttle rod and choke wire. Support both halves and remove the 4 bolts on the transmission housing.  I use a cherry picker on the front half so I can wheel it away from the rear.  Clutch is simple to replace.
You can never have enough tractors....I had 26 with one acre, then moved to a nine acre patch and now have around 80...but who's counting....have fun!
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAdon Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2012 at 9:41pm
thanks for the advice  AND the chuckle!
i will NOT let my wife read your post... right now she thinks i be stopping at two.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2012 at 9:44pm
Oops, forgot to mention the steering linkage has to be removed (but that is obvious, right??). To remove it, take the nut almost off at the front  steering arm, get a pry bar in there like you are going to pry it off...put pressure on the bar and hit the end of the steering arm with a big hammer and it will pop right out....oh yeah, leave the nut on a couple of threads or it will go flying when it lets go.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAdon Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2012 at 9:44pm
have fun?!  at 70 i finally got my first tractor... and love it at least as much as i did my first car.  this isn't a hobby - it's a passion!  (like i need to tell you that...)
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2012 at 9:44pm
Remove the stuff hanging underneath and then remove hood, steering from either end, gas line, choke rod, governor rod and oil lines in back of filter. Then if supported properly remove the angle iron from the sides and the 4 bolts holding the motor to the torque tube and should slide apart. Don't think I forgot anything, just split my C last night to switch oil pumps. There is an inspection cover under the torque tube that you may be able to see what was unhooked and maybe you don't have to split it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2012 at 9:45pm
Holy crap do I type slow!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAdon Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2012 at 9:46pm
yep i WILL proceed with all due caution.  must survive to go to the next adventure!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAdon Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2012 at 9:51pm
thanks lonnie but now i am all geared up to split it anyway... msut be something wrong in there... and am naturally curious anyway.  when i do get a "backup" B to use i will probably field strip the whole thing just so i know the condition of everything.
this is a "first love" tractor and i want to know everything about it i can.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2012 at 10:57pm
You can take those angle iron brackets off and leave them off. once you have the hood steering and fuel tank off. use a cherry picker on the rocker arm cover bolts it will hang straight and be easy to push back together.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 4:07am
Anyone else notice ?
A CA with 'hand clutch' on L/H side !
Gary
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 4:51am
Gary
That would be so you can steer with your right hand while looking behind over your left shoulder to see what is going on using the power take off equipment. Like a combine or baler so it is easier to use the hand clutch.
Splitting pictures.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 4:55am
Dang kids will try anything! Wink  I gotchya beat by a coupla years. I be a thirty eight model.
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 7:10am
When I first saw this post I thought " A CA with a narrow front". My CA has the single front wheel. Splitting these narrow fronts and SFW models is a bit more tricky. Wide fronts are a piece of cake by comparison. The front half naturally wants to stand up OK without any special attention.
EdK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EdK Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 9:46am
I split my C a few years ago to un-jam the engine. While I was in the clutch housing, after a monumental cleaning chore, I changed a few parts on the clutch mechanism and the starter ring gear. I should have gone a little further and should have attacked the shaft seal from the engine. Be sure to take a good look at everything in there and replace or fix what ever doesn't look or work right.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAdon Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 9:57am
dick L - thanks as always for informative (& encouraging) words & pix.  btw i do not begrudge you the extra 3 years on earth... but all those years in heaven (on and around tractors) you have on me make me orange (definitely not green!) with envy.
and sorry to disappoint all, the hand clutch IS on the right where it belongs... which is why i am so desperate to get the foot clutch functional again. i seem to be one hand short when steering, shifting and "clutching".
eldon - so sorry to disappoint you but i do plan to utilize that marvelously sturdy "underframe" for a variety of applications, some homemade.  plus... i ned MORE orange stuff, not less. (yes, i know, you offfered a trade.)
fyi i got this whole package (including gannon "earthcavator" )for $1000... when i was totally unaware of what "right" prices would be.  and was amazingly 2 miles from my house.  i guess it was destiny...
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 10:14am
I split my B by making a wood frame to support front .Had chainfall on toqure tube . Put pto in gear and tractor ingear ,put vice grips on pto and just cranked it apart.PS I did have other parts unfastened.
