Speed Patrol Gears
1955allisca View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1955allisca Quote  Post ReplyReply Direct Link To This Post Topic: Speed Patrol Gears
    Posted: 27 Jul 2014 at 10:33pm
I know that RC gears will slow down a WC but seems like half the people ya talk to say that speed patrol gears will do the same and the other half say they are the same as a WC. Does anybody know for a fact that they are slower or has anybody put one in a WC puller?
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2014 at 11:03pm
The instruction manual for a Speed Patrol shows speeds from 2.5-9 mph and 2 mph in reverse, the exact same as any WC.
Waukesha B, B, IB, G, styled WF, D15, 615 backhoe, 2-Oliver OC3's, 6 Ford Model T's, 3 Model A Fords, AV8 Coupe, AV8 Roadster, 1933 Ford Wrecker
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2014 at 5:23am
Mine is slower that I installed.  It came from a Speed Patrol.  Now, my 2nd is just about the same as 1st gear with a stock WC rear end.  I do not remember the ratio but I am thinking a stock rear is about a 4.4 and this is around a 6.6 and a "picker" ring and pinion option is around 7.2...  I have all this written down someplace at home, but after moving a few years ago it will be a search.
'40 WC puller,'50 WD puller,'50 M puller '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1955allisca Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2014 at 11:44am
Thanks for your replies I guess the best option would be just to check the gear ratio on one before purchasing it
