Speaking of Welders n such |
Thad in AR.
Joined: 12 Sep 2009 Location: Arkansas Points: 9731 |
Topic: Speaking of Welders n suchPosted: 16 Dec 2023 at 7:29pm |
I need to buy some Argon mix.
This has me wondering about oxygen, acetylene and argon mix prices. Has anyone bought any recently? |
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35679 |
Posted: 16 Dec 2023 at 8:14pm |
Last tank I picked up was DOUBLE what paid two years prior. That was LAST Spring, oughta be about insane now.
Thad in AR.
Posted: 16 Dec 2023 at 8:37pm |
That’s what I figured. |
Joined: 11 Sep 2009 Location: illinois Points: 90819 |
Posted: 16 Dec 2023 at 8:53pm |
What do you weld with the ARGON ? You doing aluminum ?
On standard steel, i just use CO2 ... Cheaper and works great.. Doing that for 25 years.
Codger
Thanks(1)
Posted: 16 Dec 2023 at 9:58pm |
I usually use C25 mix which is 75% Argon and 25% CO2. Lot less spatter and it produces a better wetting action at the toes or edges of the weld puddle. Straight argon is for aluminum welding only in my usage.
That's All Folks!
desertjoe
Joined: 23 Sep 2013 Location: New mexico Points: 13769 |
Posted: 16 Dec 2023 at 10:35pm |
Ditto what Steve says, Thad. I used to use the 75/25 Argon mix til they wanted me to give them the numbers to my credit card,,,,, I had a fire extenguisher from work tested by and repurposed by AirGas for straight CO2 which is MUCH cheaper and works great as an all purpose sheilding gas,,,, I go even farther and now use propane gas instead of acetalene on my cutting torch set,,, works great with the correct tip,,,
Thad in AR.
Posted: 17 Dec 2023 at 4:58am |
I’ve always used 75/25 mix for mild steel. If I can save a $ I’ll try co2. Does it use the same tank and regulator? |
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4278 |
Posted: 17 Dec 2023 at 7:35am |
I run straight argon when tig welding.
Posted: 17 Dec 2023 at 8:51am |
Thad..........., the CO2 runs at a lower pressure so normally the tanks are MARKED and remain that way for a SPECIFIC GAS.. Since your going to a REDUCED pressure, the FILLER may change the TAG and fill with CO2... ask them.... The regulator can also be used, but the fittings on the bottle / hose are different, (so you would need a new adaptor / fitting to go on the bottle..... assuming the FILLER will change the fitting to a CO2 type.)... Possibly they can remark the bottle and use the same fittings ??? That would be entirely up to the filler.
My son got a Wire feed bottle with CO2 and it would not FIT our hose.. I bought an adaptor for it... I think they had a Argon/mix bottle and remarked it for straight CO2 and left the Argon fitting on it........ thats what you need.
Edited by steve(ill) - 17 Dec 2023 at 8:53am |
DMiller
Posted: 17 Dec 2023 at 9:05am |
Have ran the Argon/CO2 blend here as seems as noted less spatter, and with shop doors open less shield drifting.
Posted: 17 Dec 2023 at 9:18am |
Here is a photo off the internet.. I cant give a PERSONAL opinion, since i have never used the MIX.... I have used CO2 for 25 years..
Edited by steve(ill) - 17 Dec 2023 at 9:20am |
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25255 |
Posted: 17 Dec 2023 at 9:37am |
75/25 is called 'Autogas' or something similar. Used for thin tin welding like doors,fenders, etc.
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42269 |
Posted: 19 Dec 2023 at 3:55pm |
Have used 75/25 for years , tried some straight CO2 and spatter was problem .
I have couple old CO2 fire bottles I keep filled with other gas , extra Oxygen and straight Argon , I made up a jumper hose to fill them from new bottles when I get one . Acetylene is hard to get , local welding shop does not handle it , MAPP gas now only. I have been using Propane for cutting and heating after changing tips on cutting and buying a Propane rosebud . Propane will work for brazing but somewhat slower on gas welding , Acetylene cost is out of site now but as I have 3 empty tanks I might get one filled just for gas welding . I have 322 cu ft Argon / Co2 tanks and oxygen tanks and a few 122 cu ft tanks also , somehow I seem to have acquired around 15 different certified tanks over the years along with my cheater Co2 tanks . Couple Oxygen 322 tanks also |
desertjoe
Posted: 20 Dec 2023 at 8:27am |
Hey Coke,,,,You know,, the supplier also told me some time back that acetylene was getting real hard for them to get so they started raising the price to consumers,,,,sound familier,,,?
I finally quit that circle and went with propane and the correct tips and I can fill the bottle from my big house tank. |
DMiller
Posted: 20 Dec 2023 at 8:43am |
Acetylene is formed by Calcium Carbide placed in water, is a mined stone and getting more difficult to find in quantity.
Coke-in-MN
Posted: 22 Dec 2023 at 4:41pm |
Big problem is Acetylene is Unstable gas and inside the bottles they use Acetone to absorb the Acetylene to make it stable for use . The bottles have a core material in them to hold the gas in suspension . Mississippi Welding here does not handle it now - is where my son gets his supplies from . They recertified my tanks and marked them as customer owned so he has to exchange his own tanks and they charge for the fill - rather than full bottle exchange .
I see Fleet Farm does Acetylene bottle fill or exchange here in Hudson WI . |
