Speaking of Unusual Front Ends |
Brian G. NY ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: 12194 Points: 2259 |
![]() ![]() ![]() ![]() ![]() Posted: 20 Jan 2014 at 9:19am |
![]() ![]() Didn't want to hijack Osage's post so I'll start a new one. Back in January of 2007 "JeremyMI" posted pictures of a very unusual NFE on a C Unfortunately I did not save the narration from the thread but I did save the pictures. As I recall, he got no responses to his inquiry of what it was. It has always intrigued me as it looks like it could be factory.
Edited by Brian G. NY - 20 Jan 2014 at 9:21am |
wjohn ![]() Orange Level ![]() ![]() Joined: 19 Jan 2010 Location: KS Points: 2185 |
I missed that original thread. Neat - I hope someone can provide some info on it.
Protrucker ![]() Orange Level ![]() ![]() Joined: 25 Apr 2011 Location: Broome Cnty,NY Points: 718 |
I wonder if it's a Farmall narrow front put on the A/C?
"ALLIS EXPRESS"
Allis Chalmers ![]() ![]() |
Eldon (WA) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Spokane, WA Points: 7765 |
One way to get rid of that poorly designed steering box....
ALLIS EXPRESS!
This year: |
Richardmo ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Rolla mo. Points: 1746 |
I sent Jeremy a text, will try and find out what the front is off of.
Pro,
You may be onto something. That upper steering shaft support looks a lot like a Farmall B. I can't find a good enuf picture of the IH B front end on the internet to see if it also looks like it. Eldon, I, too, always thought that big pitman arm and long drag link on the C and CA detracted from their otherwise good looks. Edited by Brian G. NY - 20 Jan 2014 at 10:38am |
DaveKamp ![]() Orange Level Access ![]() ![]() Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6045 |
I'll +1 for the possibility that it was adapted from some other machine... and a Farmall would be a strong possibility.
If so, whoever did it, was truely an artist! |
Steve in NJ ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Andover, NJ Points: 11978 |
Doesn't a FarmAll cub have the same type of column? Might be pirated from a Cub?
Here is the info i got from Jeremy.
I ask if was from different tractor manufactor what was it. No that front end has am casting numbers on it from allis but the steering is outside the frame with no gearbox I have been told it is a prototype Edited by Richardmo - 20 Jan 2014 at 11:52am |
Here's the best pictures I can show you for comparison of a Farmall BN front end:
"ALLIS EXPRESS"
Yeah,
I found that one but the picture of the gear box is not too good. From what I can make out, it looks different than the one on the C. However, that picture led me to believe the steering shaft support is the same as the one on the Allis C.
AJ ![]() Orange Level ![]() Joined: 31 Oct 2010 Location: mo Points: 5244 |
It could be a Farmall bulster with a C narrow front bolted to the bottom of it. Anyone know if the bulster bolt holes match up to a C narrow front support? Should be four bolt holes.
Anyone know who has that tractor? I would be interested in seeing pictures of it without a grill/radiator on it. Edited by AJ - 20 Jan 2014 at 7:34pm |
Can't fix stupid
MNLonnie ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Baxter MN Points: 4791 |
Be interesting to know what the AM casting #'s are and which part of the front end they are on.
AJ
He is good friend of mine has lots of tractors Right know he said the tractor in a shed hard to get to. I will see if about the casting #.. Edited by Richardmo - 20 Jan 2014 at 10:15pm |
David Maddux ![]() Orange Level ![]() Joined: 13 Sep 2009 Points: 2535 |
I wonder if the tractor serial number is a low one? Dave.
I would be interested in more info on this when it comes.
Can't fix stupid
acben20 ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: waseca Points: 1001 |
Bump any new news on this front end?.
Wdtractorman ![]() Orange Level ![]() Joined: 24 Sep 2013 Location: Kentucky Points: 975 |
That not a farmall front end. Looks to me like a Allis front with a old automotive box grafted into it the end of it looks just like my 52 chevy gearbox I use to have
