Source of parts to rebuild a B Water Pumps?
nowaktj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Topic: Source of parts to rebuild a B Water Pumps?
    Posted: 16 Apr 2012 at 5:38am
Hi-Has any one found a place to get bearings and seals in order to rebuild a water pump?  The one I want to rebuild is on an Allis B tractor.
Thanks in advance
Terry
D19D, D17D, WD, WC, Snobee, #83 Plow, SC Blade, 14' disk, 400 series planter, B , Terra Tiger, M Dozer w/Baker Blade, TL-12, 42S Grader, G
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 6:16am
You're much better off buying a new one and installing it. Much better chance of not having to go back later to do the job over again with the old pump. We have new pumps in stock if interested..
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 6:24am
I would 2nd Steve's opinion. Last time I did one (20 yrs ago) the parts were 2/3 the cost of a remanufactured one....and it was a real PIA to rebuild....and it leaked when I was done. Save yourself some grief (unless you have the tools and experience) and purchase new or remanufactured ones. Several of the vendors who advertise here (Tony C, Jim D, Steve, etc) all can help.....and they are great to work with.
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 6:45am
+3 on a new pump, save the aggravation and spend a few dollars more for a solution that fixes the problem.
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 3:29pm
New pump is simple way to go, can rehab your pump with seals and bearings, Minn Par, maybe Norms, and Hill Martin Corp.
615 had a leaking water pump, bought the seals and bearings, pressed old one off, put new in place and mounted up the seals, no problems.
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 3:34pm
Beena while, but last time I priced kits, it was cheaper to slap a new one on.  Not to mention that the last one I tried had such a worn shaft that we bailed and ended up with a new pump anyway.
Owner of OKtractor.com PM for an instant response on parts. Open M-F 9-6 Central.
We have new and used parts. 877-378-6543
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 7:25pm
i can not do it for$20.00 and chance losing the core also  my 2 cents  can help
  1-574-342-4545
