somewhere thars a screw missin |
Les Royer
Joined: 25 Dec 2014 Location: Carson, Iowa Points: 5593 |
Topic: somewhere thars a screw missinPosted: 27 Jun 2018 at 4:09am |
I had to take the dash board skeleton clear out of my 1999 Ford F550 to get to the heater box. The defrost/vent door had come loose of the pivot shaft aand the a/c was blowing all the cold air up onto that hot windsheild. Not the ideal set up. Only way to buy a new door was to buy the complete heater box at the tune of 200 bucks. I don't think so chump. I McGuyvered the fix for free. \ When I got it all back together I only had one screw left over. I was pretty darn proud of myself. It werked flawlessly.
I still gots my A/C but it's clear out in the barn now.
chaskaduo
Joined: 26 Nov 2016 Location: Twin Cities Points: 5200 |
Posted: 27 Jun 2018 at 4:22am |
You fixed Fords better idea.
Hubert (Ga)engine7
Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6500 |
Posted: 27 Jun 2018 at 4:29am |
That was a smart idea: take a heater box that is prone to have problems and build a truck around it. Hope I don't ever have to get to the heater box on my '99 F150. I would have more than one screw loose when I finished. BTW how long did that simple little job take?
Grayray
Joined: 12 Sep 2009 Location: Ambridge PA Points: 3858 |
Posted: 27 Jun 2018 at 5:35am |
could the loose screw be missing from the nut behind the wheel?
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24768 |
Posted: 27 Jun 2018 at 5:48am |
Needed to replace the heater core in my late mother's 80 Mustang that had A/C back in 1985ish. Called dealer for ballparl cost $200 for the core, $600 for labour..says it's an EIGHT hour job! A non-A/C job is like 20 minutes(2 hoses, 2 screws,yank and dun).Had to remove 1/2 the dash,'free' the Freon,a Real PITA job. Took me 2 1/2 hrs and I had 5 or 6 'extra' screws.sigh.not a big deal.heater worked and no squeaks. Total cost was $20 for a new Ford/OEM core.got that from my customer.
Thad in AR.
Joined: 12 Sep 2009 Location: Arkansas Points: 9668 |
Posted: 27 Jun 2018 at 6:26am |
Several mustangs and Tarus and such were totaled due to a heater core. Some have ran coolant to the ac core to get heat.
desertjoe
Joined: 23 Sep 2013 Location: New mexico Points: 13729 |
Posted: 27 Jun 2018 at 8:02am |
Shoot Thad,,,more'n one way to skin a cat besides f*** UMmmm never mind,,,,,, ![]() Chit I always thought you was susspossed to have some screws left over,,,,just to proove the Mfgrs used too dang many,,,,,
JoeO(CMO)
Joined: 11 Sep 2009 Location: Cent Missouri Points: 2696 |
Posted: 27 Jun 2018 at 8:58am |
don't worry.
I heard many times and have seen in new vehicles extra screws...one may be damaged or missed on assembly. Vehicles go down the line pretty fast and when time runs out, extra parts get deposited in vehicle, sometimes not necessarily near where the were meant to be. I spent many years with coworker who worked on assembly line for big-3, same story.
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12243 |
Posted: 27 Jun 2018 at 10:49am |
Had a '95 (I think) Dodge Intrepid (*shudders*).
One cold night the wife and kids were coming home after Christmas at my parents. I was in another car. By the time we got to our house, and they pulled in the driveway, I could see that the windows were down a couple inches. Hmmm.....that's odd, it's like 0 outside. Well, the heat was stuck on full. Not the fan, but the damper. I started to look into it. What fun! Laying across the door sill, head by the accelerator, just about enough clearance under there for you hand, I tried to take out that motor, you could loosen it but didn't have the clearance to take it all the way out. Funny thing though, I turned the key on to test it out and see if I could see it moving, and it closed! With it loose, you could turn the control up and down and the motor worked perfectly. So I thought maybe something had stuck, and exercising it fixed it if at least temporarily, so I tightened it up. It worked, until you went full heat, and it would stick again. I stopped at the dealer and told them what happened. Naturally they want to interrupt you 25 times and tell you what's wrong. I finally got done telling them all I had checked and observed, and they said, "That can't happen, blah blah blah...." Well, I'm here to tell you, it CAN happen, I can make it happen time and time again. "No sir, you see, it's blah blah blah....." OK then, what will it cost to have that replaced? Holy crap, they told me it would be a time and materials job, had to disconnect air bags, disconnect all this crap, remove the dash, then the part was $800, etc....etc....No job in the book so just shop rate per hour. Mmmkay.....I left. Went home, loosened the screws so it freed up, tightened them then backed each one out 1 turn (metal screws in plastic, so still held good). Worked perfectly for the rest of the time I owned the car. But that can't happen.
CTuckerNWIL
Posted: 27 Jun 2018 at 11:03am |
Back in 71, I took the carb apart on my 48 M5 Studebaker pick up. When I got it back together I had a couple pieces left over. Tossed em in the bed of the truck in case I every figured out where they went and drove off
![]() I bought a new Granada in 77 and within a month, the temperature control wouldn't work. When I went to pick it up, the guy in the service department had to "show me sompin". He reached under the dash and said, "you gotta pull or push on this bolt to change the temperature setting. They didn't have the parts needed to fix it, so they ran the cable out under the dash and attached a 1/4-20 bolt and nut to the cable end. |
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18943 |
Posted: 01 Jul 2018 at 1:30pm |
![]() WAY to go Les!! Even Shameless will be proud of you! |
