Some progress on the 1 Ton GMC,,, |
Page <12 |
Joined: 11 Sep 2009 Location: illinois Points: 90838 |
Posted: 17 Oct 2023 at 8:41pm |
I doubt the bed drops 7.5 inches with a load on it... Do you have axle STOPS on the frame to limit the max travel ?
Thad in AR.
Joined: 12 Sep 2009 Location: Arkansas Points: 9731 |
Posted: 18 Oct 2023 at 5:43am |
7.5” does seem high. What are the bed frame rails made out of?
truckerfarmer
Joined: 26 Jan 2013 Location: Watertown, SD Points: 3312 |
Posted: 18 Oct 2023 at 6:44am |
7.5' isn't all that much. Consider how much space there is in the wheel well of a factory box. The rubber bump stops squish down, so you lose some more clearance there. Also you need to consider axle oscillation. If one side drops down, such as exiting a driveway, crossing the gutter at an angle, the outside tire on the other side goes up. This is amplified on a dually.
'53 WD, '53 WD45, WD snap coupler field cultivator, #53 plow,'53 HD5B dozer Duct tape.... Can't fix stupidity. But will muffle the sound of it! |
desertjoe
Joined: 23 Sep 2013 Location: New mexico Points: 13769 |
Posted: 19 Oct 2023 at 6:16am |
Hey Steve,,,I have no idea what "Axle Stops" are and cannot seem to still be able to post pics here,,for some reason,,,,,? Hey Thad,,the bed frame is made of 2" X 2" X 1/4" square tubing spaced 20" apart with one running down the middle parallel to trk frame. . The dude that built the frame originally used 3" X 3" X 1/4" channel 6" long welded together that worked out just right to give me 5 1/2" tire clearance so I believe I will leave it go based on all of ya'll's comments ![]() Whoops,,just thought of something else,,,gonna have to crawl under it again to check out the placement for the Hide-a-way goose neck,,,,Chit,,,!!
im4racin
Joined: 12 Jun 2017 Location: Garrison ND Points: 1125 |
Posted: 19 Oct 2023 at 6:42am |
Axle stops are on the bottom of the frame rail and rest on the axle tube when over loaded
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35690 |
Posted: 19 Oct 2023 at 7:23am |
Unless removed by a previous owner or corrosion there should be rubber blocks on a steel bracket just above the axle tube on both sides under the frame channel. Granted over time the rubber does decay and disintegrates away the brackets will still be there.
Thad in AR.
Posted: 26 Oct 2023 at 5:10pm |
We’re ready for an update.
tadams(OH)
Joined: 17 Sep 2009 Location: Jeromesville, O Points: 11411 |
Posted: 27 Oct 2023 at 2:21pm |
He's probably headed back your back and can't control himself
desertjoe
Posted: 27 Oct 2023 at 11:03pm |
Actually Guys,,,I put that project on HOLD for a short time as I haVE run into all kinds of Guv-ment BS in trying to get a title,,, Now,,get this,,,I was told by Guv-ment peoples that ALL states now require a "Certified APPRAISALL" TO BE PERFORMED BY A "CERTIFIED APPRAISER" who can charge an amount of money chosen by,,,,,,,,hisself. AND,,you will NOT receive a title unless you do so,,,!! That is in addition to 6 other pieces of official guv-ment documents you gonna need. I spoke with my State Representative about this new BS law and he tells me it originated in the Eastern states because of a thriving car and trk thieving business that buys cars with only a bill of sale, then gets their buddies to apply for lost titles and presto they got a high priced car/trk " wit CLEAR TITLE IN HAND,,,,typical guv-ment process,,,don't punish the guilty,,,,PUNISH EVERYBODY111 ok, I'm done,,, |
Codger
Posted: 28 Oct 2023 at 6:49am |
Your insurance agent can get you a "surety" bond which will allow you to process for a certificate of title. This is a govt. bond action that starts a search for an owner of a previous titled vehicle. If nobody steps forward claiming ownership, (requires proof on their end within one year of bond issue) the surety bond is released, the bond rescinded, thus freeing the title to free and clear status.
Basically obtain the surety bond from your insurance agent and go to your DMV with the paperwork and file for a new title to your vehicle. All will process normally and if nobody steps forward claiming ownership, you will be notified as such. I have done this with seven antique heavy trucks in the past and the process is seamless with exception of the surety bond which I think cost $100.00. This is a federal bond, not just Illinois.
Edited by Codger - 28 Oct 2023 at 6:51am |
That's All Folks!
desertjoe
Posted: 28 Oct 2023 at 7:57am |
Well Codger,,,like the "New Sherriff In Town" the process HAS changed in all states like I was told by my State Representative. You NOW will have to pay for the Surety Bond based on "TWICE THE VALUE" of whatever you're trying to title stated on the NEW APPRAISAL REPORT! and NOT what you just paid for that tractor or car or,,,anything!! Your Surety Bond will be based on TWICE the appraised value! Yes, it used to cost $100 for a surety Bond from your friendly Insurance agent but that friggin New Sheriff in Town BS is going to surprise lots of people,,,,,
DMiller
Posted: 28 Oct 2023 at 9:02am |
MO Requires that a No Title Vehicle go to a MSHP Inspection Station, has to have numbers ran and a full inspect of any component as Engine with a s/n, any questionable numbers and it Magically GOES AWAY without compensation. Now as with cars and trucks of the 1920s/30s that were NOT titled originally, and the owners LONG Dead, pulled from old barns or fields or woodlots, those can be inspected as NOT stolen and issued a NEW MO DOR ID Tag with a State generated number, that an Officer will Special Rivet to the hard frame of the cab. Takes some paperwork and a release from the property owner you get it from, sometimes a lawyer document trail will assist in a timely manner.
Codger
Posted: 28 Oct 2023 at 10:55am |
Just did this last week and no changes I've seen for a truck I picked up after harvest. $100.00 surety bond and the process is already started to obtain title. The truck, (1962 B-62SX Mack) has been setting in the same spot near 20 years since last use. Titled owner long deceased and property sold to current owner long ago who did nothing with the truck.
It may wash out as the deceased owner's family is looking for the title, but I went my proven way to ensure something gets done. Taking a politician's word without fact checking is playing "Russian Roulette" with your own interests. Typically, they don't have your interest at the forefront but rather what will generate revenue yet keep them in office at election time.
That's All Folks!
Page <12 |
