Some nos stuff fs |
Mikez
Topic: Some nos stuff fsPosted: 18 Apr 2020 at 11:16pm |
Hi everyone
Have some parts for sale. -516610 bolts that fit forage harvester, 780 they bolt the knives in place. -516611 nuts -519095 lower or 512553 fit forage harvester, 780. Feed roll arm. Might have bearings that go in this. -519097 upper -225119 seal fits CA steering arm. -4501050 studs fit A,R,D15D,D17D,D19,WD45D,HD3,2CP -4042704 dist, cap fits 2CP,A,R,C,D19 -314078. HTP-216 jointer and frog fits plows. -HTP-212 -314262 clamp fitting row crop cultivators. -511575 chain fits side delivery rake, roto baler. -800619 or 316430 master lift arm, RH fits G -800620 or 316431 master lift arm, LH fits G -800617 collar fits the above arm -901270 set screw fits above collar -226625 pulley, front crank pulley fits WC,WD,WD45 used on tractors with adj. front axles or single wheel. -507226 bearing fits 60,60A,60H,66,72,2E,2A,150P,170P,116,4C,FH,FB,SDR,RB,110,1RCH,2RCH,66,CHD,90CHD,780,1RCP,2RCP,GSA,60SA,90SA,100SA,100SP,122,801,802 -571108 or 336670 or 345726 fits a bunch of drill planters, unit type planters. ![]() ![]() ![]() Let me know if any interest. Thanks Edited by Mikez - 18 Apr 2020 at 11:19pm |
Hunt4Allis
Posted: 19 Apr 2020 at 8:10am |
Is the 225119 the seal for the gearbox and if so will it work on a 1953 and what do you want for it? (I have a small leak on my steering box and I believe this is the seal that would need to be replaced to stop the leak?)
Thanks Matt 👍 |
jollymon68
Posted: 19 Apr 2020 at 9:16am |
how much for the manifold studs for the d15d, part number 4501050.
WisconsinElkman
Posted: 10 Aug 2020 at 9:26am |
How much are you asking for the pulley 226625?
Mikez
Posted: 05 Dec 2020 at 7:30pm |
Bump
