solar battery chargers
John R. Mrotek View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John R. Mrotek Quote  Post ReplyReply Direct Link To This Post Topic: solar battery chargers
    Posted: 16 Jun 2010 at 11:21am
How can I test to see if my solar battery charger is producing energy into
my 12 volt battery?
John R. Mrotek
split51 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote split51 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2010 at 11:33am
I have not been around a solar charger but couldnt you hit it with a voltmeter to see.
M Diesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote M Diesel Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2010 at 12:56pm
They don't really make all that much juice, which means voltage is doable but might be a bit tough to observe ifn a large battery is connected. However measuring amperage in one of the charger leads would be easy enough.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2010 at 1:41pm
It should put out 12 volts, but it's the current you are interested in.  You should be able to read 12 volts anywhere in almost any light.  At least the ones we have work that way.
Wendell(OK/TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wendell(OK/TX) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2010 at 12:21am
If it's one of the little 1.5 watt panels, it will put a new meaning to "trickle charge".  Used one on a tractory battery and it brought it from 11.5 to 12.5 volts in just over a week.  Made a decent battery maintainer though until it got broke.  Best thing to do is check it with a voltmeter or multimeter, do it with the panel only connected to the meter, not with the battery connected or you will get a false reading.  As long as it is putting out 12+ volts then it will charge, just hard to say how fast.  Good luck
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2010 at 2:50am
At full sun, with a regulating charge adapter the unit we use at our farm for cabin power delivers 13.8v and 2.3 amps.  I bought the both of them from Northern tool.  You will get little charge if it cannot get above true battery voltage or 2.2v per cell or 13.2 for 12v and 6.6 for a 6v, same goes for generator charging off the engines.
