snow |
Joined: 11 Sep 2009 Location: illinois Points: 90838 |
Topic: snowPosted: 18 Nov 2022 at 5:42pm |
sounds like New York is getting pounded with snow. 3-4 feet already and maybe a couple more feet coming tonight.. West wind blowing over the Great Lakes carrying it in... Be careful up there !!
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35690 |
Posted: 18 Nov 2022 at 6:07pm |
BooFoolow is getting POUNDED with Pretty, at least is NOT here.
klinemar
Joined: 14 Sep 2009 Location: Michigan Points: 8074 |
Posted: 18 Nov 2022 at 7:00pm |
Grand Rapids and Kalamazoo got 15 inches and more coming.
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4078 |
Posted: 18 Nov 2022 at 7:22pm |
you guys are lucky
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12071 |
Posted: 18 Nov 2022 at 7:40pm |
Gotta' watch that Lake effect snow! It seeks up on ya!! Yikes!
dr p
Joined: 24 Feb 2019 Location: new york Points: 1539 |
Posted: 19 Nov 2022 at 6:51am |
Not sure about lucky. 66 inches out by the wife's family. Said it was coming down 5 inches an hour with thunder and lightning. Newer a good sign when Jim Cantoree is reporting from outside your house
DMiller
Posted: 19 Nov 2022 at 6:58am |
WOW!!
Thunder Snow!! Shamers sure tuned that beast machine up with his fresh cash load!! Blowing pretty across the lakes making it ever worse! |
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42271 |
Posted: 19 Nov 2022 at 11:02am |
Only got a few inches here in eastern MN but the dang cold has set in now .
Son is just finishing up his order to dealer of 25 plows and seems dealer now wants another 10 plows as has got a bunch of orders for different mounting types . Most of plows were made for compact and small utility tractors but a couple skid loaders also . I plowed the church next door the other nignt , not a lot of snow but got it cleaned off with the pickup truck plow . |
Coke-in-MN
Posted: 19 Nov 2022 at 11:45am |
My 665 Skid with one of sons new plows he just completed and delivered . Special order as it has 2' wings added to blade . Ordered for clearing snow from appartment complex , to use as both pusher and a plow . https://www.facebook.com/profile.php?id=100063760264642
Edited by Coke-in-MN - 19 Nov 2022 at 2:49pm |
Pat the Plumber CIL
Joined: 11 Sep 2009 Location: Springfield,Il Points: 4988 |
Posted: 19 Nov 2022 at 1:28pm |
Painting them the right color, looks good Coke . Did your son give Shameless a deal on that tree puller ? Sounds like they worked out a deal , all the snow Shameless can make means more snow plow sales .
1964 D-17 SIV 3 Pt.WF,1964 D-15 Ser II 3pt.WF ,1960 D-17 SI NF,1956 WD 45 WF. |
Coke-in-MN
Posted: 19 Nov 2022 at 2:55pm |
He has several different colors he paints units in - all the back frames are painted black but blades come in several colors . One thig is he designedthe plows with a single hydraulic cylinder for turn system rather than 2 rams , and every plow has a relief valve installed so if something is hit it wont blow a cylinder or damage the plow .
Unsure what deal they worked out - but know he was liking the unit for what it did . I delivered 2 plows a while back - one to Indiana and other to Ohio for son. |
Coke-in-MN
Posted: 19 Nov 2022 at 3:10pm |
Coke-in-MN
Posted: 19 Nov 2022 at 3:21pm |
allischalmerguy
Joined: 11 Sep 2009 Location: Deep River, IA Points: 2895 |
Posted: 19 Nov 2022 at 5:39pm |
Those are really nice units Coke! Yes darn nice.
Coke-in-MN
Posted: 19 Nov 2022 at 9:23pm |
The green plow is for John Deer and has the double mounting pins on bottom of face plate , the light and smaller Compacts have one set of pin locations and the larger units use pins in different place so he makes them accordingly .
That unit is going to a dealer and was built so it fite either loader face plate . He uses the single cylinder to shorten the distance plow is in front of machine , If you have seen the A frame used on many units it puts plow about 2' further out from front of machine ( like a truck mounted plow ) Plow come with 4, 5, 6 web backers on plow blade and also 2 different weights of the frame . Notice the 3rd link on top which is pinned for down pressure or pin removed to float plow . Also the design allows the plow to stay parallel to surface when angleing plow as there is some foat in the overall geometry . Edited by Coke-in-MN - 19 Nov 2022 at 9:31pm |
