snow thrower on G
Mike(NEOhio) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike(NEOhio) Quote  Post ReplyReply Direct Link To This Post Topic: snow thrower on G
    Posted: 10 Mar 2013 at 5:21pm
Can anyone identify the snow thrower that came on my G?  The rear end mounts to the same place as the Mott mower and runs off the same idler and tensioner pulleys to a midshaft, then another belt to the front and a chain drive to the auger.  The frame is channel iron with a clevis welded between them at the rear.  Turnbuckles attach the frame to the tool lift bar.  Looks like it had a crank and cable to turn the chute.  I can't figure out how to post picture here.  You can see it on the YT "Help Identify" page.  Scroll back a ways and you'll see them.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2013 at 9:56am
I have a manual by Jensales that shows all the attachments made by Allis Chalmers for the G and there is no snow blower in it.
The loader made by Midwest is not in it.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike(NEOhio) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2013 at 5:30pm
Thanks, Dusty
I never really thought it was from AC.  I was thinking maybe Mott because it mounts to the same drawbar bracket and the pulley castings are the same as the flail mower.  It doesn't look home build either.  Also uses the same idler and tensioner pulleys.
