Snapcopler
1947WC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1947WC Quote  Post ReplyReply Direct Link To This Post Topic: Snapcopler
    Posted: 16 Aug 2019 at 2:05pm
What is the correct way to put on a new snapcopler spring repair kit?
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2019 at 3:17pm
Not sure , but there is an easy way, and a few hard ways to do it
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2019 at 9:53pm
you talking snap coupler or lift latches?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1947WC Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2019 at 11:48am
Lift latches
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2019 at 2:55pm
Get the old drive in pins out, and you got it made!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2019 at 11:16pm
Never done this but wouldn't a slide hammer  work to pull old pins assuming they still have a head?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1947WC Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2019 at 11:40am
Thank you for the information guys.
Tom IA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom IA Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2019 at 12:43pm
I have a slide hammer welded to a vice gripe clamp it on the head slide hammer it plus turn it like to unthread it at same time sometimes have to add heat
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1947WC Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2019 at 3:42pm
Thank you Tom.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2019 at 4:59pm
  I have a piece of threaded rod that screws in place of the regular screw on my vice grip. I welded a nut to the one end and have a piece of steel, drilled to slide on the threaded rod.
