snap coupler to 3 pt |
Marlyn nwia
Silver Level Access
Topic: snap coupler to 3 ptPosted: 31 Mar 2024 at 9:22pm |
What mounting components need to be removed from a D17 IV with a snap coupler hitch to be compatible to mount a factory three point?
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54462 |
Posted: 01 Apr 2024 at 4:46am |
None, if you use the factory made 3ph conversion...
Posted: 01 Apr 2024 at 6:33am |
Drop off the drawbar and bail. Then, remove the two vertical bail hanger brackets (4 holes in each one) and you can install the factory 3 point hitch. If you are going 100% swap out, you'll then need to drop off the snap coupler spring and bell assembly inclucing the brake pedals and shaft.
