Snap Coupler ?s and 3pt ?s |
Post Reply |
79fordblake
Orange Level Joined: 01 Jul 2010 Location: West Kentucky Points: 827 |
Posted: 03 Jul 2010 at 6:08pm |
1.)Is there supposed to be a release lever operated from the driver seat for the snap coupler on the WD45? If so my tractor is missing it b/c I have to get under the tractor and pull the pin down for it to release the plow, planter, etc... Which isnt very safe when I am working by myself. 2.) Is there something that should be on the lift arms of the 3pt to keep them swaying back and forth so much side to side. I usually have chains on them bolted to the drawbar to stabilize the sway but took them off the other day when I replaced the bolts/washers, etc.. on the hitch.On the bright side I used the tractor for the first time today with a bushog behind it after installing the straight pipe, boy does she bark.
Thanks.
Edited by 79fordblake - 03 Jul 2010 at 6:17pm |
Glockhead SWMI
Orange Level Joined: 12 Sep 2009 Location: South West Mich Points: 2657 |
Yes, a lever on top of the shift tower.
Not sure about the sway. Mine doesn't move around too much. I am sure someone else can help you out with that.
79fordblake
Could you possibly get a pic? That would be very helpful.
I corrected alot of the sway after replacing and tightening bolts. It is way better than before. I still think there is to much though.
I have one arm that I have to straighten, I bent it the other day while using the pond scoop in hard ground. Edited by 79fordblake - 03 Jul 2010 at 6:22pm |
Post Reply | |
