Snap coupler lift arm latch springs |
EPALLIS ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Illinois Points: 1151 |
![]() ![]() ![]() ![]() ![]() Posted: 08 Aug 2011 at 8:49pm |
I'm in need of a set of replacement lift arm latch springs. Does AGCO handle these? Does anyone know their price? Any assistance would be greatly appreciated. Thanks!
daveingreenbay ![]() Silver Level ![]() ![]() Joined: 09 Oct 2009 Location: Green Bay Points: 245 |
Check with Tracy Martin, he should have everything you need. excellent quality, at a fair price
Tracy Martin TN ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10736 |
Actually I am out of the springs at present. Roger Van Camp will have the correct springs. Some vendors offer a spring ,but they are not correct. The originals had a double coil loop on each end. It keeps it from coming off. Make sure to get the correct ones, you won't be happy with the others. HTH Tracy Martin
AC WD45 ![]() Orange Level ![]() ![]() Joined: 28 Sep 2009 Location: Mid Michigan Points: 2060 |
Almost any hardware store that sells springs can have them ordered. I got mine from ACE
German Shepherd dad
John (C-IL) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Illinois Points: 1654 |
Doc Smith has them
Doc is a great guy too. Tracy Martin
Clay ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Udall, Kansas Points: 9797 |
How do you remove the twist rivet which holds the spring? One of the ones which holds the spring is broken.
BobHnwO ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Jenera Ohio Points: 693 |
Got mine at ACE also.
Clay, it is called a drive screw. It is hard also, heat it with a torch until red, let it cool ,it should soften up enough to carefully drill it out. Really helps if you have a vertical milling machine. HTH Tracy Martin
Jeff(WD45-SATX-TN) ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Sewanee, TN Points: 443 |
Tracy,
How easy should the couplers be to open and close? I bought a used set and they are tough. How do ya get them to loosen up? Was thinking about just soaking them in degreaser for a while.
1954 WD45 NF "Iron Tater"
Auntwayne ![]() Orange Level ![]() Joined: 23 Apr 2011 Location: Edwardsville Il Points: 1589 |
A degreaser removes "grease", it is not a lubricant !!!
Jeff, they should not bind on hinge rivet. They over center on the spring. New springs make them real stiff to open. Spray some Kroil on and into them. That should help things if hinge rivet isn't bent. HTH Tracy Martin
