Snap Coupler Compatibility |
TimCNY ![]() Orange Level ![]() Joined: 15 Apr 2014 Location: Upstate NY Points: 1551 |
![]() ![]() ![]() ![]() ![]() Posted: 29 Apr 2023 at 10:12am |
With what other A-C tractors (more "modern" than the WD45) will snap couple implements for a WD45 be compatible? Sadly due to a fall in November 2021 that rendered me totally paralyzed from the neck down (surgeries and, literally, a multitude of miracles now have me doing terrific upper body, low back/buttocks & legs very slow to return), I have to sell my WD45. I expect you guys can picture why, and also what I mean by "more modern" because I can climb steps from front/side but not so much for getting on up over the back. I have a guy that wants just the tractor and loader but not the 3-14 plows or other snap coupler equipment. I do want to keep those implements since they work great with the WD45, so I'm wondering what other A-Cs they'd fit. Otherwise I'll probably put them up for sale locally and look for a cab tractor.
Thanks in advance, - Tim
I need more than 200 characters for my "signature." I'd love to see that changed to 250!
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24718 |
I have 3 D-14s and they all hookup to the SC 3-14 plow ,SC Oxnard rear blade, C subsoiler as well as the 3PH tiller that's bolted to a SC<>3PH adapter.
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54239 |
There are some differences in length of the tongues for WD's to D series, but in general you can interchange them, give or take a few inches on the tongue...
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21990 |
If you are replacing a WD-45, you don't want a D-14 or D-15. You want/need a D-17 or bigger and all the snap coupler implements you have will interchange to to the larger tractor. (D17/19 or 190/190XT snap coupler models)
Dirt Farmer ![]() Silver Level Access ![]() Joined: 15 Sep 2020 Location: Illinois Points: 441 |
Sent you a PM
55allis ![]() Orange Level ![]() ![]() Joined: 30 Jun 2020 Location: Griswold Iowa Points: 1010 |
Put steps on the 45, I know DJ Tractor has them…
Been meaning to make a set for my 45, even as a young guy… |
200Tom1 ![]() Orange Level ![]() ![]() Joined: 03 Jun 2019 Location: Iowa Points: 1232 |
Get yourself an early D17.
Thanks, guys! Been a little busy expanding my vineyard at the house. That plus all the other usual springtime chores and - not on here much. I also appreciate the private messages, if I can wrangle it I'll make steps per Dirt Farmer's plans so I can keep the tractor. Fired it up the other day and it's developed a skip, shut it down so as to not make anything worse. Time for a tune up!
