Snap Couple Disk questions
MikeSMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeSMN Quote  Post ReplyReply Direct Link To This Post Topic: Snap Couple Disk questions
    Posted: 07 May 2010 at 7:59pm
How much would a guy have to give to get a disk like this in MN?  How wide do you think this one is?  Do the chains fit into the snaps or is another piece needed?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeSMN Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2010 at 8:00pm
... and are blades and spacers readily available if needed?
Denis in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2010 at 8:02pm
Chains go to lift arms but I think you need or atleast should have the bar that goes between the latches for extra support due to the weight blades should be generic and readily available but not cheap
Edited by Denis in MI - 07 May 2010 at 8:02pm
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeSMN Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2010 at 8:09pm
Thanks Denis.  I have the bar in place.  Just looking for something handy for the D15 II - should make a decent combination, right?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2010 at 8:14pm
I would think it would be a good match but I don't have alot of experience with d-series tractors, I don't know if the front end would get kind of light on you with the disk picked up but you should have enough tractor to use it.
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2010 at 8:19pm
Finding the spools shouldn't be a problem. The gottcha with all of those discs are the balpak bearings. They are only available at AGCO for like $160 each. I have a stack of the spools from a disc that I took apart, but no bearings. The blades are pretty generic, you may not find blades with the round hole, but you may be able to find some that will work.
That should be an eight foot disc. I have seen good ones sell for several hundred. One in that condition could still bring at least a couple hundred. The rule with discs is the smaller they are the more they will cost. You could put $500 in that one in parts without breathing hard. Heck, just new blades woiuld be will be from $16 to $20 each for 28 of them, you do the math. If you used a couple of used bearings for $30 to $60 each so there you have as much as $680 and you haven't bought any hardware, hangers, spools or bearing spacers. If you wanted to restore that thing to like new condition you could put $1000 into it.
When you got done you would have a great disc though.
Edited by John (C-IL) - 07 May 2010 at 8:30pm
wf32 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wf32 Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2010 at 8:23pm
Mike are you looking for a disc. If so I have a 10 ft one for sale in Brownsville Mn
call 507-482-6940  Phil
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeSMN Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2010 at 8:46pm
wf32 - sent you a pm.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeSMN Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2010 at 8:54pm
John, that is excellent advice, exactly what I was looking for.  Thanks!
This page was generated in 0.104 seconds.
