Small engine question
Ben (MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Topic: Small engine question
    Posted: 13 Feb 2012 at 8:52am
My Simplicity snow thrower has a 5 hp Tecumseh engine on it that runs best on 1/4 choke. Is there anything I should do to correct the choke issue? Thanks.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2012 at 9:59am
I don't think that is anything to worry about.  Do you have the manuals?  There is a link here to get the manuals, and you might get better answers there as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2012 at 10:15am
Sounds like dirty main jet. You probably want to remove the carb and clean the main jet along with the emulsifier tube that runs up the center. It should run good with no choke when warmed up.
