small drum mower and AC 5020
dxk9dtman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dxk9dtman Quote  Post ReplyReply Direct Link To This Post Topic: small drum mower and AC 5020
    Posted: 18 Apr 2024 at 11:44am
Hi everyone!
So, I bought a 5020 2WD although I have hills.  It does have a front loader.   But no other accessories.  I was thinking about buying a used 48" John Deere brush hog or Tractor supply 48" brush hog.
From my research the tractor is too light to pull a square baler.
RE: small drum mower:
Has anyone used a small drum mower to cut hay behind the AC 5020 2WD or think it would work?   I need something to cut my hay and then I was thinking of just gathering by hand, maybe a mini baler.  Any advice would be great.
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2024 at 2:28pm
I think a 5020 is too light to do any kind of hay work. Even a small drum mower will weigh 800ish pounds I guess. Most of them fold back in transport mode so your swinging most of the weight of the mower farther (3 to 4ft) behind the rear of the tractor. Even with the loader frame I think you're to light. I've heard of people cutting hay with a rotary mower with a side removed but I never tried it
Probably be better to find a sickle mower or sell the 5020 and get a bigger tractor
Edited by thendrix - 18 Apr 2024 at 2:29pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2024 at 6:52pm
You'll have to do some research, small drum mowers are out there that will fit and operate...
Here is an example, not any kind of endorsement...
Edited by DiyDave - 18 Apr 2024 at 6:53pm
Travis2766 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis2766 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2024 at 7:21am
Find a decent sickle mower, way less cost and no worries if it’s going to be too heavy. A 5020 will handle a hay rake but a baler that may be out of the question. I’ve baled small squares on a flat field with a Farmall Super C which is about the same hp but forget a wagon. So it’s do able
190XT Series III, D17 Series IV, D15 Series II, All Crop 66 and a whole mess of equipment.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2024 at 10:53am
one of my customers finished up baling with a 273 new holland hooked to a kubota b7100 when his case whent down ,  he said he did 100 bales with it , i cant be leive the little tractor could even get the baler turning .  b 7100 is only as big as my 720
